03-03-2009, 22:23 | #1 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Dominican Republic Age: 49
Member: 92317 Status: Offline Sonork: 100.1591991 Thanks Meter: 223 | coral 500 100% modulo v1.63 Servicio: Coral-500 Checkeando datos, espere... Action: unlock unlock method-1 Boot ... loader: standard type: 4 Mantenga Presionado el boton Power ! loading... next part... boot answer: 01 Deje de presionar el boton power ahora ! Boot Done Seleccionar velocidad ... 115200 Seleccionar velocidad Done Connecting ... Flash 00EC:257E Connecting Done Check hardware ... sw version: VDF-P108C1B02-FrEsPtIt-DG02 g3yBV2.0 Mar 28 2008 11 01 53 04.12. Check hardware Done Check parameters ... Check parameters Done backup critical area ... leyendo eeprom-static... Archivo guardado: C:\Program Files\InfinityBox\Pana01\Coral-500_eeprom-static_20090303-172000.B1E.bin loading data... data loaded leyendo eeprom-security... Archivo guardado: C:\Program Files\InfinityBox\Pana01\Coral-500_eeprom-security_20090303-172001.B1E.bin leyendo eeprom-complete... Archivo guardado: C:\Program Files\InfinityBox\Pana01\Coral-500_eeprom-complete_20090303-172008.B1E.bin reading additional data... Archivo guardado: C:\Program Files\InfinityBox\Pana01\Coral-500_lock-area_20090303-172021.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Escribir ... Erasing: lock-area Writing: lock-area Escribir Done Finalizado, tiempo usado: 51 sec Quite/coloque la bateria ahora ! thanks infinity team |
The Following User Says Thank You to cdmagsm03 For This Useful Post: |
03-03-2009, 23:49 | #2 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Quote:
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. | |
06-21-2010, 20:49 | #3 (permalink) |
No Life Poster Join Date: Aug 2008 Location: brazil Age: 47
Member: 846805 Status: Offline Sonork: alex cavalcante Thanks Meter: 261 | COM3 [VCP0] selected Mَdulo v1.71 Dispositivo: Coral-500 Verificando Dados. Aguarde... Açمo: Destravar unlock method-1 Boot ... Pressione e SEGURE o Botمo de Ligar! e-gold: 820000 loading... next part... boot answer: 01 Solte o Botمo de Ligar! Boot Done Determinar Velocidade ... 115200 Determinar Velocidade Done Connecting ... Flash 00EC:257E Connecting Done Check hardware ... sw version: VDF-P108C1FM G B02-FrEs-DG01 g3yBV2.3 16 00 52 09.03.01 21.38.01 Check hardware Done Check parameters ... Check parameters Done backup critical area ... Lendo eeprom-static... Arquivo Salvo: C:\Arquivos de programas\InfinityBox\Pana01\Coral-500_eeprom-static_20100621-164857.B1E.bin loading data... data loaded Lendo eeprom-security... Arquivo Salvo: C:\Arquivos de programas\InfinityBox\Pana01\Coral-500_eeprom-security_20100621-164858.B1E.bin Lendo eeprom-complete... Arquivo Salvo: C:\Arquivos de programas\InfinityBox\Pana01\Coral-500_eeprom-complete_20100621-164904.B1E.bin reading additional data... Arquivo Salvo: C:\Arquivos de programas\InfinityBox\Pana01\Coral-500_lock-area_20100621-164917.B1E.bin backup critical area Done Check memory ... Erro: Firmware Desconhecido. Leia a Flash e Envie Para o Suporte Check memory Failed Finalizado. Tempo Gasto: 59 sec Remova/Recoloque a Bateria! No unlock...Please |
06-21-2010, 20:59 | #4 (permalink) |
Member: 846805 Status: Offline Sonork: alex cavalcante Thanks Meter: 261 | COM3 [VCP0] selected Mَdulo v1.71 Dispositivo: Coral-500FM Verificando Dados. Aguarde... Açمo: Destravar unlock method-1 Boot ... Pressione e SEGURE o Botمo de Ligar! e-gold: 820000 loading... next part... boot answer: 01 Solte o Botمo de Ligar! Boot Done Determinar Velocidade ... 115200 Determinar Velocidade Done Connecting ... Flash 00EC:257E Connecting Done Check hardware ... sw version: VDF-P108C1FM G B02-FrEs-DG01 g3yBV2.3 16 00 52 09.03.01 21.38.01 Check hardware Done Check parameters ... Check parameters Done backup critical area ... Lendo eeprom-static... Arquivo Salvo: C:\Arquivos de programas\InfinityBox\Pana01\Coral-500FM_eeprom-static_20100621-165732.B1E.bin loading data... data loaded IMEI: 000000g020A0C0L Lendo eeprom-security_000000g020A0C0L... Arquivo Salvo: C:\Arquivos de programas\InfinityBox\Pana01\Coral-500FM_eeprom-security_000000g020A0C0L_20100621-165734.B1E.bin Lendo eeprom-complete_000000g020A0C0L... Arquivo Salvo: C:\Arquivos de programas\InfinityBox\Pana01\Coral-500FM_eeprom-complete_000000g020A0C0L_20100621-165740.B1E.bin reading additional data... Arquivo Salvo: C:\Arquivos de programas\InfinityBox\Pana01\Coral-500FM_lock-area_20100621-165759.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Escrever ... Erasing: lock-area Writing: lock-area Escrever Done Finalizado. Tempo Gasto: 63 sec Remova/Recoloque a Bateria! Seleccionei o Modelo 500FM e deu certo ...Thanks |
The Following User Says Thank You to Alexandro Monte For This Useful Post: |
coral 500 after unlock phone is dead | lamran | Infinity-Box | 34 | 08-04-2011 17:29 |
coral 500 cable help | devil6684 | Infinity-Box | 3 | 04-23-2009 23:22 |
Coral 500 FM death after User/phone/lock cod. | fclavel | Infinity-Box | 6 | 03-25-2009 18:08 |
coral 500 with pinfinder | sewkar | Infinity-Box | 11 | 01-24-2009 18:19 |
coral 500 coral500 unlock | mrfixit | Infinity-Box | 10 | 01-12-2009 10:33 |
