09-03-2016, 23:22 | #1 (permalink) |
Freak Poster Join Date: Sep 2012
Member: 1811743 Status: Offline Thanks Meter: 6 | PLZ ADD THIS REMOVE MICLOUD Redmi Note 3 CPU: MT6795 but i cant info or flash or hard reaset give me this error Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6795 BB_CPU_NME : [MediaTek] Helio[X10]|MT6795_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x92 NAND Flash : NOT INSTALLED eMMC Flash : 11010030313647373200E0F2326AA251 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:09 Reconnect Power/Cable! Operation : Format FileSystem [ v1.55 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Brom Init not done Boot Error! Operation Failed Elapsed: 00:00:11 Reconnect Power/Cable! but miracle box support and i cane flash and format and read flash scater or bin see infinty team this info by miracle box crack 2.27a then 50% Waiting for USB Port... Set MTK USB Port (COM6) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6795 SW:0000 Ver: CA00 Downloading Boot8 ... EMMC Size: 0x03AB400000 Flash Type: EMMC INT/EXT RAM Size: 0x0+0x0 Reading infr(EMMC)... id:LRX22G version:5.0.2 model:Redmi Note 3 brand:Xiaomi manufacturer:Xiaomi PROINFO BaseAddr:0x80000 Size:0x300000 NVRAM BaseAddr:0x380000 Size:0x500000 PROTECT1 BaseAddr:0x880000 Size:0xA00000 PROTECT2 BaseAddr:0x1280000 Size:0xA00000 SECCFG BaseAddr:0x1C80000 Size:0x40000 LK BaseAddr:0x1CC0000 Size:0x400000 BOOT BaseAddr:0x20C0000 Size:0x1000000 RECOVERY BaseAddr:0x30C0000 Size:0x8000000 SECRO BaseAddr:0xB0C0000 Size:0x600000 PARA BaseAddr:0xB6C0000 Size:0x80000 LOGO BaseAddr:0xB740000 Size:0x800000 EXPDB BaseAddr:0xBF40000 Size:0xA00000 TEE1 BaseAddr:0xC940000 Size:0x500000 TEE2 BaseAddr:0xCE40000 Size:0x9C0000 SYSTEM BaseAddr:0xD800000 Size:0x80000000 CACHE BaseAddr:0x8D800000 Size:0x25800000 USERDATA BaseAddr:0xB3000000 Size:0x2F4880000 OTP BaseAddr:0x3A7880000 Size:0x2B00000 FLASHINFO BaseAddr:0x3AA380000 Size:0x1000000 Done. 1. Phone switch on with battery 2. Need to open the USB debugging 3. Setting defined or line to phone 4. Need Phone root. 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Insert USB cable. In some cases Required Hold BootKey 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Waiting for USB Port... Set MTK USB Port (COM6) Open Port Err: >>*** the Port be occupied. |
09-04-2016, 20:47 | #7 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Hello jaydi means don't hold any vol keys and don't use boot key read logs once u can clearly understand Sent from my S_plus using Tapatalk |
09-05-2016, 06:41 | #8 (permalink) | |
No Life Poster Join Date: Aug 2005 Location: MOON Age: 43
Member: 174173 Status: Offline Thanks Meter: 115 | Quote:
