03-20-2008, 22:14 | #1 (permalink) |
Freak Poster Join Date: Jan 2008 Location: LiByA
Member: 693427 Status: Offline Thanks Meter: 17 | plz help download flash form soppurt cbu MT6219 when flash phone give me this log COM3 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6219:8A01]... CPU: MT6219 high speed boot enabled boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: B000B101000000:B000B100000000 flash: Sharp Intel std [def 0008x002000 007Fx010000] 8Mb detecting chip #01 in region #00... flash: B000B004000000:B000B000000000 flash: Sharp Intel std [def 007Fx010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: B000B101000000:B000B100000000 flash: Sharp Intel std [def 0008x002000 007Fx010000] 8Mb detecting chip #03 in region #00... flash: B000B004000000:B000B000000000 flash: Sharp Intel std [def 007Fx010000 0008x002000] 8Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: B000B101000000:B000B100000000 flash: Sharp Intel std [def 0008x002000 007Fx010000] 8Mb detecting chip #01 in region #00... flash: B000B004000000:B000B000000000 flash: Sharp Intel std [def 007Fx010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: B000B101000000:B000B100000000 flash: Sharp Intel std [def 0008x002000 007Fx010000] 8Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 02/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: SZMI19_05C_PCB01_GPRS_MT6219_EV.MAUI_05C_W0616_X50 1_ARABIC_V1.BIN ver. sw2: MAUI.05C.W0616.X501.ARABIC.V1, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 2 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: B000B101000000:B000B100000000 checking area[00000000]: 00000000-007FFFFF... flash: B000B004000000:B000B000000000 checking area[00800000]: 00000000-007FFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 01 eeprom/ffs area: 00800000:00600000-007FFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[SZMI19_05C_PCB01_GPRS_MT6219_EV.MAUI_05C_W0616_X50 1_ARABIC_V1.BIN]]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom[SZMI19_05C_PCB01_GPRS_MT6219_EV.MAUI_05C_W0616_X50 1_ARABIC_V1.BIN]_20080320-225137.B0E.bin flash: B000B101000000:B000B100000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Area: Firmware flash: B000B101000000:B000B100000000 Write: Firmware error: error# 0000B4B4 20:5[01]: Erase fail or program sequence error when set with SR[4,7]. 10:4[01]: Program fail or program sequence error when set with SR[5,7]. 04:2[01]: Program suspend in effect. error: flash write error: 00200000:00002000 error: error# 0000B0B0 20:5[01]: Erase fail or program sequence error when set with SR[4,7]. 10:4[01]: Program fail or program sequence error when set with SR[5,7]. error: flash write error: 00200000:00002000 error: error# 0000B4B4 20:5[01]: Erase fail or program sequence error when set with SR[4,7]. 10:4[01]: Program fail or program sequence error when set with SR[5,7]. 04:2[01]: Program suspend in effect. error: flash write error: 00200000:00002000 error: error# 0000B0B0 20:5[01]: Erase fail or program sequence error when set with SR[4,7]. 10:4[01]: Program fail or program sequence error when set with SR[5,7]. error: flash write error: 00200000:00002000 error: error# 0000B4B4 20:5[01]: Erase fail or program sequence error when set with SR[4,7]. 10:4[01]: Program fail or program sequence error when set with SR[5,7]. 04:2[01]: Program suspend in effect. error: flash write error: 00200000:00002000 error: error# 0000B0B0 20:5[01]: Erase fail or program sequence error when set with SR[4,7]. 10:4[01]: Program fail or program sequence error when set with SR[5,7]. error: flash write error: 00200000:00002000 error: error# 0000B4B4 20:5[01]: Erase fail or program sequence error when set with SR[4,7]. 10:4[01]: Program fail or program sequence error when set with SR[5,7]. 04:2[01]: Program suspend in effect. error: flash write error: 00200000:00002000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Write Fail Finished, time used: 465 sec Remove/Install battery now ! --------------------------------------------------------------- |
plz help 1680 camera standby | med26 | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 04-19-2010 17:30 |
plz help mmmmmmmmmmmmmmmme ?? | vmin81 | UST Pro II | 3 | 03-30-2010 12:59 |
plz help me | lloydgsm | FuriousGold | 3 | 03-29-2010 20:08 |
plz help me its urgent | lloydgsm | SETool2 | 2 | 03-29-2010 17:45 |
plz help me | lloydgsm | SETool2 | 6 | 03-29-2010 13:10 |
