12-04-2007, 18:43 | #1 (permalink) |
Junior Member Join Date: Nov 2007
Member: 641339 Status: Offline Thanks Meter: 0 | Getek TK806 dual sim does'nt work |
12-04-2007, 20:48 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,537 | hello! is it double MCU phone? Only double MCU phones can simulatiously hold 2 SIm cards in Air. if it is 1 mcu phone- you can only switch between them |
12-05-2007, 18:12 | #3 (permalink) |
Member: 641339 Status: Offline Thanks Meter: 0 | Thank you, In phone settings there is line switching options. I tried it but I can't use the phone. on the screen for SIM B It writes emergency. I can see the phone book of the SIM B card but I can't recieved the signal of the operator. By the way on the screen Both of the SIM cards antenna's are seen. Is there a software problem. What must I do? please help me. |
12-05-2007, 18:49 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,537 | hello! i cant see answer to my single question- is it duble MCU phone? by your answer i just can guess that yes, it is double MCU phone. Then problably second MCU part contain invalid for your country IMEI. try to edit it and if not help then format FFS. but i think that it is IMEI problem |
12-05-2007, 21:34 | #5 (permalink) |
Member: 641339 Status: Offline Thanks Meter: 0 | Thank you for your patience again I think it is single MCU phone because I found one IMEI number ( as you see I don't know too much thing about MCU either I think that you mentioned MCU for IMEI ) If not how can I understand whether a phone is double MCU or not. |
12-05-2007, 22:08 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Hello, As I can see from your message you don't have Infinity-Box yet. To activate (unlock) your phone and be able to use any sim card with it you need to visit www.infinity-box.com and buy Infinity-Box software. After you have bought it you will be able to unlock your phone (of course, if your phone has MT62xx CPU inside). How to unlock phone: 1. connect cable to phone 2. run Infinity-Box software 3. press "unlock" button If you have more questiond please make "search" in this forum and you will find a lot of interesting information. |
12-05-2007, 22:13 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,537 | hello! you can open your phone and check how many processors is there. if it is single processor- this type phones can not hold both cards in air at the same time. only 2 processor phones can hold both SIm cards in air at same time |
E71 dual sim no work !!! | djibrilcoulibal | Chinese Models & Cloned Phones | 2 | 11-05-2009 14:56 |
GETEK TK806 2.cpu 6205 flash needed? | technicservice | Infinity-Box | 3 | 08-28-2008 19:21 |
GETEK TK806 German language pack | ab1009 | Infinity-Box | 3 | 12-01-2007 14:02 |
GETEK TK806 need FULLFLASH Urgently | MasterJey | Infinity-Box | 2 | 11-01-2007 01:07 |
sim Emu 3,4,5 does'nt work Sony Ericsson P800 | deande2002 | Sim Cloning and Scaning | 2 | 04-25-2003 01:49 |
