02-28-2016, 12:13 | #1 (permalink) |
No Life Poster Join Date: Nov 2014 Location: Lucknow
Member: 2298369 Status: Offline Thanks Meter: 440 | Micrommax a250 always show wrong flashing ffile BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x86 NAND Flash : NOT INSTALLED eMMC Flash : 3000011139473631D22200323F70E6C5 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 29G61 [eMMC] : FLASH_CID : 1101003031364739320022D2C5E6703F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000003AB400000 [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB] DEV RID : 3AB010436461837BAA647024D7EB687A INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6589 , Project : MTK6589 , Storage : eMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC NOT supported by BootLoader! [BL_ERROR] : STORAGE : Break Flashing! This Firmware will kill phone! Operation Failed Elapsed: 00:00:14 Reconnect Power/Cable! I LOAD OG FILE FROM MICROMAX FTP, BUT WHEN I FLASH WITH SP TOOL SET OK, HANDSET SHOW UNFORTUNATELY ERROR PROBLEM. |
02-28-2016, 12:23 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | You can off "HW Check" option to flash FW. It made for make users safe in case of not correct FW's, but some vendors make their flashfiles with broken info, which make such result. |
The Following 4 Users Say Thank You to JayDi For This Useful Post: |
02-29-2016, 11:19 | #3 (permalink) |
Member: 2298369 Status: Offline Thanks Meter: 440 | Ur firmware check facility is unique feature, and i try to always take profit from it, sometime there is no version given in slip so i always start firmware writing from cm2 if i not success in minor cases then i try other tool. This feature make superior ur tool to other. |
