Prada ke850 unlocked COM6 [VCP0] selected module v1.58 Device: LG-KE850 Checking data, wait... Action: unlock read unlock codes Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0089:887E Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE850_eeprom-static_20081215-170835.B1E.bin reading eeprom-static2... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE850_eeprom-static2_20081215-170835.B1E.bin loading data... data loaded imei: 35030526000000100 reading eeprom-security_35030526000000100... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE850_eeprom-security_35030526000000100_20081215-170837.B1E.bin reading eeprom-complete_35030526000000100... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE850_eeprom-complete_35030526000000100_20081215-170840.B1E.bin backup critical area Done Check memory ... loading data... data loaded code: 18257914 Finished, time used: 21 sec Remove/Install battery now ! ;) |
good share thanks for shareing your successful unlocking logs thanks again |
THANKS BR GOOD INFINTY TEST REPORT THANKS INFINTY TEAM BR SOHAILKH::::d |
good report . |
very good shairing keep it .............. |
@NADEEM GONDAL Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. |
it's been great !!!!!!! aah ! |
