Old 02-12-2017, 04:59   #1 (permalink)
bronce's Avatar
Member: 488875
Sonork: 100.1626294
Thanks Meter: 1,129
Question team is this supported or not yet ?
is this supported or have problem in emmc chip?
status: hang on acer logo then reboot ( this is acer z530 )
software hang/stuck in this, kindly see logs
Scatter Load Ok , BaseBand : MT6735 , Project : cci6735_35u_l1 , Storage : EMMC
Files found : 11 , Set to Flash : 10
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Brand : acer
Device Model : acer_T02
Device CPU : MT6735
Device IntName : T02_aap
Device Version : 5.1
Device Compile : 10/22/2015 8:46:11 AM
Device Project : ALPS.L1.MP3.V2.3_CCI6735.35U.L1_P92
Device ExtInfo : T02
Ready to Flash!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 108 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x93
NAND Flash : NOT INSTALLED
eMMC Flash : 56000170303030310C135038C9CC33F3
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x70 , OEM : 0100
[eMMC] : FLASH_INF : [KINGSTON] , 80001
[eMMC] : FLASH_CID : 70010056313030303850130CF333C2C9
[eMMC] : FLASH_LEN : 0x00000001C3000000
[eMMC] : FLASH_UCP : 7216 MiB [eMMC 8 GiB]
DEV RID : 0xE1B133725562AD8FC003BC6CFECF282A
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6735 , Project : cci6735_35u_l1 , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3729 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000001C80000-0x0000000004E00000
Erase Error! Something went wrong!
Operation Failed
Elapsed: 00:01:46
Reconnect Power/Cable!
Old 02-12-2017, 06:02   #2 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
check with emmc test its read only ?
Page generated in 0.18995 seconds with 8 queries
