Old 11-09-2015, 11:22   #1 (permalink)
Deepesh Sharma's Avatar
Member: 1301233
Sonork: Closed
Thanks Meter: 9,297
intex aqua star 2 hd unable to read pattern lock
error when read pattern lock
Operation : Read PatternLock [ v1.05 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
 ====  Wait for phone...
Phone found! [ 29 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC7730/SC7731 loader eMMC v1.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
Reading PatternLock ...
PatternLock Not Set!
Elapsed: 00:00:19
Reconnect Power/Cable!
3. Insert cable
Phone found! [ 29 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Elapsed: 00:00:15
but formate sucessfully
Operation : Format File System [ v1.05 ]
Settings : SmartFormat is On
3. Insert cable
Phone found! [ 29 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Done!
Elapsed: 00:00:16
Old 11-09-2015, 13:32   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
Try to read pattern with pac file selected.
Post result.
Br.
Old 11-09-2015, 13:48   #3 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
No, problem in FlashIC.
It 8GiB. SPD protocol allow map for FlashMode just first 4. In some cases code will sit more far, than first 4 GiB.
The Following User Says Thank You to JayDi For This Useful Post:
Old 03-16-2016, 10:33   #4 (permalink)
Member: 1819354
Thanks Meter: 2
unable to flash aqua star 2 with miracle box
dear sir
i try to flash with miracle box intex aqua star 2 but it is not showing error
SU2Serial Port.
1.Please Make sure install the driver
2.The Phone may be required to read and write keys
3.Pulled low may not, manually set.
Definition Applied
1. Power Off Phone , Remove Battery, Insert Battery Back
2. Please Hold BootKey(UP and DOWN),Insert USB cable
3. Use Miracle Boot Key In cases Boot key not Find
4. Battery Should be Charged more then 50%
Scanning USB Serial port...
SU2Serial Port: COM40
Connecting to Phone,Wait..
Please RePower on & off
Definition Applied
count:=0_
None SU2Serial Port.
Definition Applied
SU2Serial Port: COM37
Done.
Infor: SPRD3
>>Initialize boot22...(Factory)
please help me sir
Old 03-16-2016, 10:41   #5 (permalink)
JayDi's Avatar
Member: 462970
Originally Posted by paragdmude View Post
dear sir
please help me sir
There is one solution - Burn it.
Old 03-16-2016, 17:58   #6 (permalink)
Member: 1819354
Thanks Meter: 2
dear sir
please give me proper solution not this
Old 03-16-2016, 20:16   #7 (permalink)
JayDi's Avatar
Member: 462970
dear sir
Check product section, where you posting. Try think for a while.
Old 03-17-2016, 05:34   #8 (permalink)
avtarkaint's Avatar
Member: 452162
Sonork: 100.1592470
Thanks Meter: 440
dear sir
Bro this is infinity box section, for miracle box query ask in their section they will help you. Next time take care while posting your doubt & question.
Old 03-17-2016, 09:48   #9 (permalink)
Member: 1819354
Thanks Meter: 2
sorry bhai
realy sorry
Page generated in 0.19072 seconds with 8 queries
