06-07-2022, 18:53 | #1 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Madeira Island Age: 47
Member: 85718 Status: Offline Thanks Meter: 449 | Prestigio PSP5504 DUO imei fail Someone could check the log please? Br Hugo Edit : Now done , have unticked the Force Brown. Operation : Repair Security [ v2.34 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM9) MODE : PRELOADER PORT PORT : 9 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! BROM : Enforcing BootROM PTFN : MTK USB Port (COM10) MODE : BOOTROM PORT : 10 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : LEGACY [MTK] BROM : MEID : F4708165D04D82D35B32B6342E63E8A2 BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : CHANGE : v1844 AGENT : Found MT6582 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 4B0001154D5658371E5901425F81C2EE DAInf: 4 : 2 : 135 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 1501004B3758564D4201591EEEC2815F NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 DRAM : 0x0178 EMI : DEV : INFINITY EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0 INIT : 0xBC : eMMC [ 0x40000000 : [ 1,00 GB ] ] DRAM : DRAM: 0x40000000 [ 1,00 GB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: CID : 1501004B3758564D4201591EEEC2815F EMMC: VEN : SAMSUNG : OEM : 0 : ID : 4B3758564D42 : PRV : 0x01 EMMC: VEN : SAMSUNG : K7XVMB EMMC: SNN : 1495199426 ( 0x591EEEC2 ) , MF : 8/2014 EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00080000 [ 512,00 KB ] USER : 0x1D2000000 [ 7,28 GB ] SRAM: 0x00020000 [ 128,00 KB ] DRAM: 0x40000000 [ 1,00 GB ] CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 , EVOL : 0x0000 RNID : F15AD366446DEAD530FAA0EB7787643B STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed Error : Failed to setup HS_USB port! Error : Failed to read initial info! Device Erased or Damaged >>> Seems as something wrong with device! Check battery charge and device state! Reconnect Power/Cable! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Last edited by ct3im; 06-07-2022 at 19:00. |
06-07-2022, 19:01 | #2 (permalink) |
Member: 85718 Status: Offline Thanks Meter: 449 | Operation : Repair Security [ v2.34 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM9) MODE : PRELOADER PORT PORT : 9 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : LEGACY [MTK] BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : CHANGE : v1844 AGENT : Found MT6582 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 4B0001154D5658371E5901425F81C2EE DAInf: 4 : 2 : 135 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: CID : 1501004B3758564D4201591EEEC2815F EMMC: VEN : SAMSUNG : OEM : 0 : ID : 4B3758564D42 : PRV : 0x01 EMMC: VEN : SAMSUNG : K7XVMB EMMC: SNN : 1495199426 ( 0x591EEEC2 ) , MF : 8/2014 EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00080000 [ 512,00 KB ] USER : 0x1D2000000 [ 7,28 GB ] SRAM: 0x00020000 [ 128,00 KB ] DRAM: 0x40000000 [ 1,00 GB ] CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 , EVOL : 0x0000 RNID : F15AD366446DEAD530FAA0EB7787643B STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! NVRAM : 0x74028B3A NVRAM : State : Ok! INFO : WiFi MAC : 8C7716E8D43F INFO : BlTh MAC : 3A1A462E2016 INFO : IMEI[1] : 354922060550701 INFO : IMEI[2] : 354922060550719 INFO : set IMEI[1] : 354922060616148 INFO : set IMEI[2] : 354922060616155 Update NVRAM ... Update NVRAM Ok! Done! Elapsed: 00:01:25 Reconnect Power/Cable! |
