02-25-2008, 13:44 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: uk
Member: 508072 Status: Offline Thanks Meter: 1,621 | problam detacting txrx with spreadtrum cpu can able to find during prossess rx is moving like 12345 but tx is still on 2 i think this is majer problam i have phone with connector type 2x5 what shuld i do now urgent help need plz |
02-25-2008, 14:42 | #5 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Quote:
1. be sure that CPU type selected correctly 2. be sure that cable inserted completely If still no luck: please, open phone and give me detailed information about CPU type (complete CPU name) via e-mail: [email protected] | |
02-25-2008, 15:10 | #6 (permalink) |
Member: 508072 Status: Offline Thanks Meter: 1,621 | ok plz tell me how to work with this cpu then i can realize i m write or worn and if i m going wrong then i will tell u what think i made wrong i any one can tell me whole process with screen shot i will thank full to him |
02-26-2008, 06:59 | #8 (permalink) |
No Life Poster Join Date: Sep 2007
Member: 599037 Status: Offline Thanks Meter: 103 | hello mr infinity support... i hav also seen that onllt mtk cpu is supported in infinity and thats y ur customers and tended to buy the other chinies boxes... plz add the support of other all cpus in infinity as soon as possible....thanx.. w8ing for ur response. |
02-26-2008, 18:16 | #11 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | @peter002 you must thisnk before write something @joni_rajpura You must make everything exactly by manual instead of think about "moving or not moving..." Did you press and hold phone power buton ? Did you read manual and followed iot exactly as described ? Here is manual especially for you: http://www.infinity-box.biz/download..._PinFinder.pdf Please, read it and you will see detailed pictures. After you have read it, please, explain here what you have tried to do and what is wrong. One more advice: if still no luck after all reading I recommend you make "Reverse" button pressed and repeat process. Questions: 1. What is CPU chip name in your phone ? (open phone and post here exact CPU chip name) 2. Are you sure that this phone has Rx/Tx pins on bottom connectors ? (some phones has no Rx/Tx on connector) 3. Did you opened phone and checked Rx/Tx points on phone PCB ? (some phones has Rx/Tx on PCB but not on phone bottom connector) Please, post here exact answers Last edited by InfinitySupport; 02-26-2008 at 18:42. |
02-27-2008, 04:53 | #12 (permalink) |
Member: 508072 Status: Offline Thanks Meter: 1,621 | yes sir i do all this as u said but still no luckse i show in pic. rx is moving in prosess but tx cant move in with mtk cpu both rxtx moved one by one so i cant understand why tx is not moving |
02-27-2008, 07:44 | #13 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Thank you for TOTAL IGNORANCE ! Please, read this again: http://67.15.194.130/vbb/showpost.ph...7&postcount=11 and see how many times I write "please" there, what questions was asked and what ZERO answers I have got. I have no reason to continue this discussion due to total respect absence and total ignorance. This thread is good example how people NO NEED to do. Last edited by InfinitySupport; 02-27-2008 at 08:56. |
02-27-2008, 08:39 | #14 (permalink) |
No Life Poster Join Date: May 2006 Location: Sudan
Member: 281857 Status: Offline Thanks Meter: 214 | yes . i tested in cect c1000 {spreadtrum cpu }its moved one side . it was rx side but after programme found it as pin 12 the tx side moved to 13 . so it work like that |
ْHow To Format Spreadtrum Cpu With SpiderMan | SiLver GSM | USB Pinfinder | 100 | 06-22-2012 11:11 |
:: Read Flash & Format Spreadtrum CPU Sucess With Spider-Man :: | SiLver GSM | SpiderMan | 18 | 08-20-2011 16:01 |
A stramge problem with spreadtrum cpu.. | kmaxmax | SpiderMan | 1 | 07-31-2008 07:20 |
PCB board how can i get it to work with spreadtrum cpu pinouts auto search | sagylove | SpiderMan | 3 | 05-29-2008 13:19 |
ZT6618 with spreadtrum cpu | aria_mobile | Infinity-Box | 3 | 10-07-2007 19:33 |
