problem after unlock Alcatel 306 hello to product support, first my operations unlock after unlock phone restart i flash phone with comcel file download to support after try unlock again and restart, after repair securuty and phone locked for all network, after repair imei original, and unlock phone same after repair security again and full format not really not found any operation for unlock what need do? here latest log to FFS COM62 [VCP6] selected modulo v4.13 Servicio: Alcatel-306X, 306A Checkeando datos, espere... Habilitada la deteccion avanzada del chip Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Mantenga Presionado el boton Power ! 19200 fixed Conectando, espere... Iniciando [6223:8A08]... CPU: MT6223 alta velocidad de boot On chip: 0011:98CC:A00C status: 01 Tamaño del boot packet: 0400 Deje de presionar el boton power ahora ! Boot Done ====> Iniciar ... detecting chip #00 in region #00... Flash 01227E22202200:2BEA0000000000 Flash Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 numero de flash chip/regiones detectadas: 01/01 Iniciar Done ====> Seleccionar velocidad ... 921600 Seleccionar velocidad Done ====> Iniciar bootcode ... interesting cpu type found Iniciar bootcode Done ====> Comprobar la integridad del firmware ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.E12E5 352.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN_E493EE46].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: E12E5352 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN project-id: MAUI.08A.W08.36.SP1.V34, 46EE93E4 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification Version: 962 provider: 306A-2ACECO3 Personalización CI96NH10 Personalización XI96NH10 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished Estado sim-lock: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Comprobar la integridad del firmware Done ====> Comprobar el contenido del firmware ... Comprobar el contenido del firmware Done ====> Backup de datos requeridos ... leyendo Alcatel-306X,306A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08 A_W08_36_SP1_V34__ffs... Archivo guardado: C:\Users\Gabi\Desktop\Alcatel-306X,306A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08 A_W08_36_SP1_V34__ffs_20111229-182201.B0E.bin Imei original: 01259400473930 Flash 01227E22202200:2BEA0000000000 Backup de datos requeridos Done ====> Revisión de datos requeridos ... Revisión de datos requeridos Done ====> Operacion Especial ... Operacion Especial Done ====> Escribir ... Escribir Done ====> Finalizado ... FFS formatting... Flash 01227E22202200:2BEA0000000000 Finalizado Done Archivo guardado: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-306X,306A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08 A_W08_36_SP1_V34__system_log_E12E5352_E493EE46_201 11229-182244.B0X.bin Finalizado, tiempo usado: 4 min 7 sec Quite/coloque la bateria ahora ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
