12-11-2007, 15:22 | #1 (permalink) |
Junior Member Join Date: Jun 2005 Age: 46
Member: 152553 Status: Offline Thanks Meter: 2 | problem avec kg275 ne s'allume pas apres debloquage Device: LG KG275 Checking data, wait... Action: unlock read unlock codes Boot... Press Power button now ! Checking... boot answer: 01 Boot Done Set Baud... Set Baud Done Connecting... flash: 0001:011A Connecting Done Check free space... flash chip supported sw version: ULC2GL KG270 P16 AFR V10a XXX-XX APR 02 2007 +0 Check free space Done Check parameters... Check parameters Done backup critical area... Reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sta_20071211-104510.B1E.bin loading data... data loaded imei: ///////////////// Reading [eeprom-sec_/////////////////]... file saved: backup_eeprom-sec_/////////////////_20071211-104512.B1E.bin Reading [eeprom-dyn_/////////////////]... file saved: backup_eeprom-dyn_/////////////////_20071211-104513.B1E.bin backup critical area Done Check memory... loading data... data loaded code: //////// code: //////////////// Finished, Remove/Install battery now ! Time used: 13 sec |
12-11-2007, 16:33 | #2 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Morocco in my shop Age: 40
Member: 179651 Status: Offline Thanks Meter: 92 | Not Posible Brother Just Calc Code Kille Your Mobile Press And Hold Power On Button Because This Models Need Long Time For Power On After Unlocking BROTHER U HAVE ERROR IN SELECT MODELS YOUR MOBILES IT S KG 270 NOT KG 275 |
12-11-2007, 17:03 | #3 (permalink) |
Member: 179651 Status: Offline Thanks Meter: 92 | mon frere deboqué le avec le méme model a la liste de software KG 270 me son lire le code testé les 2 methode de direct unlock et bon chance |
12-11-2007, 19:20 | #6 (permalink) |
Member: 179651 Status: Offline Thanks Meter: 92 | Brother Make Sure Your Batterie Plien Charging Andd Testing Your Mobile Not Power On Go To Support Area Download Flashe File From Support And Flashing Your Mobile Good Luck Brother |
12-28-2007, 16:49 | #7 (permalink) |
Freak Poster Join Date: May 2004 Location: CANADA Age: 47
Member: 66744 Status: Offline Thanks Meter: 38 | hello i'd tried to unlock my kg275 but i did one error; i wanted press "unlock" botton but i did "repair"(with furious gold); the phone is dead and it steal dead after tryng flash it with MG160 flash file and KG275 after that but it still dead???!!!! i ask for any ather solution please |
12-28-2007, 17:22 | #8 (permalink) | |
Freak Poster Join Date: May 2006 Age: 41
Member: 276850 Status: Offline Thanks Meter: 717 | Quote:
12-29-2007, 05:54 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @mjaid1977 next time posts with non-English text will be deleted w/o notice @walid07 use Infinity-Box, flash files and repair_eeprom files for KG270 model @Black_Attack it's good idea to write text like "only soltion" if you already tried to use other solutions. In other case it's better to think more before write. |
probleme avec le support | nizarios-alg | HWK | 2 | 10-21-2008 13:12 |
probleme avec HWK aide moi SOS | nizarios-alg | HWK | 9 | 09-19-2008 08:58 |
probleme avec le j210 | olenadal | Sony Ericsson | 1 | 09-06-2008 03:22 |
Telephone Bb5 Ne Connecte Pas | BABsuika | BB5BOX | 1 | 03-11-2008 13:38 |
