Problem with b159 Fail to unlock b159 also with the 1.41. first step completed but uart unlock failed. Here is the soft details. HARDWARE : SCNNZ317 COMPILE : May 28 2010 (17:51:49) REALEASE : Mar 29 2007 (20:00:00) SW Version : QSC6010 SCNNZ 3170 --------------------------------------------------------- Phonce code : 0000 Finished, time used: 4 sec |
1.41 Have No Problem U Can Use Uart Unlock Without Any Problem Check Ur Cable And Selected Port Wbr <<<Megatron>>> |
Sir my cable and selected port is ok the problem is that when click on sp unlock phone goes in the download mode but when press the uart unlock set not connect with the pc. I already using the ver 1.41. ? I read the info after press the read information button then how my cable and selected port will be faulty sir. |
You Are Using Usb Cable To Unlock Uart Mode? Use RJ45 E210 Cable And Press Uart Unlock Wbr <<<Megatron>>> |
1. use sp -unlock via usb cable in emergency mode. 2. use uart -unlock by rj45 cable. ur handset will be unlock. |
