Old 04-28-2009, 08:51   #1 (permalink)
Member: 288521
Thanks Meter: 685
problem with infinity shell
i have problem with infinity shell
when i run it always says i need download update.. i download update and run it then when i look at shell again says download same modules..
i look at the modules and they are all up to date...
its a pain... how can i sort it?
Old 04-28-2009, 10:06   #2 (permalink)
Member: 128745
Thanks Meter: 16,936
try deleting all old infinity shell from your PC
and then download new one , and try
Old 04-28-2009, 23:06   #3 (permalink)
Member: 288521
Thanks Meter: 685
ok will try tomorrow when start work.
Old 04-29-2009, 00:04   #4 (permalink)
Member: 288521
Thanks Meter: 685
tried it.. still the same..
Old 04-30-2009, 19:14   #5 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
This problem may be a result of incorrect installation. Probably you have moved modules in other folders after installation of Shell located in wrong folder.
If you can not check support area manually for updates but you want to check updates via Shell I suggest you to uninstall Infinity-Box software and then install it again.
Problem with MultiBox Shell balar Multi-Box 3 01-14-2010 11:13
Small Problem with Latest SHELL 3stanGsm Z3X-Team Products 1 11-16-2009 12:58
Problem with new shell update 3.1, firmware 2.1 jands Z3X-Team Products 2 11-15-2009 19:03
Problem Launching Infinity Shell kasamiko Infinity-Box 4 04-01-2009 05:29
Problem with Infinity SN Reader!! galaxi Infinity-Box 3 04-03-2005 03:54
Page generated in 0.17353 seconds with 10 queries
