problem by InfinityBox CM2MT2 === DongleManager [Infinity] v1.72 [18/12/2018 15:10:18] === Searching... Card-Reader: Generic EMV Smartcard Reader 0 HWID: 00027D0C00001942 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): xxxxx Firmware version: 0137.02 "UK Edition" status: On Last launched Application: 0040 v.0200 => Activations: - 00: Infinity-Box/Dongle v.0137 - 07: #7 |
everything is Ok. Do you have any problem ? |
It does not open the latest modules. of CM2MT2 |
delete CM2MT2 folder completely !!! install CM2MT2 again result ? |
Same as in the whole PC format and likewise does not open the program |
Do u have fault.bin,, if yes then attach fault.bin file here (file sharing services are not accepted) or contact to support via e-mail team will tell u wht to do after tht |
Does other modules running fine? Does your pc have any kind of usb sharing/sniffer/debugger installed? Sometimes antivirus also makes some problem. So disable antivirus, install CM2MT2, add to exclusion/trusted list and try to run. Br. Infinity-Box Team |
Open the other normal programs but this last two update. It does not open me : CM2SCR..CM2MT2 |
uninstall it and then run CM2 |
already desistame everything. the 1.58 check if it works well InfinityBox CM2MTK https://i.ibb.co/VYsYMTg/Captura-de-pantalla-1.png |
do you have fault.bin file in folder with CM2MT2 software ? |
