Old 05-27-2007, 13:45   #1 (permalink)
Viking's Avatar
Member: 19585
Thanks Meter: 19
Problem with Motofone F3
After use button Format FFS in phone no ringtones, only voice help. Flashing not help. Phone work OK, but without rings.
How repair?
Old 05-27-2007, 20:49   #2 (permalink)
Member: 42981
Sonork: 1583521
Thanks Meter: 9
Hi
How repair?
hi pls which cable did u use f3 cable pinout and if pinout how because i`ve tried many times not working help pls [email protected]
Old 05-27-2007, 21:01   #3 (permalink)
mishiko_gsm's Avatar
Member: 85537
Thanks Meter: 66
To access the advanced settings, press * * * [number code] * [action]
QUOTE
Phone Setting Number Code
Change Language 520
Select time format 470
Set Voicemail number 644
Voice Prompts ON | OFF
(can also be toggled by pressing
[action] on the volume menu) 510|511
Keypad tones ON | OFF 250|251
Auto keypad lock ON | OFF 260|261
Set SIM Pin 300
SIM Pin ON | OFF 310|311
Reset Factory settings 000
Restricted Calling (Phonebook only) ON | OFF 160|161
Prepaid Balance Display ON | OFF 500|501
Set Balance Inquiry Number to # * 642
The last two are only available if supported by the service provider.
Additionally, you can display Phone information details by pressing:
* * 9 9 9 9 * [action]
Undocumented Codes - Use at your own risk!
Switch something unkown ON | OFF 130|131
Switch something unkown ON | OFF 400|401
Display network currently receiving service from 480
Display list of networks within range 481
Show OK (?) 700
Enter a number, then text (CAUTION) 701
try this bro
Old 05-29-2007, 21:21   #4 (permalink)
Viking's Avatar
Member: 19585
Thanks Meter: 19
super, many THX, problem solved
Old 05-30-2007, 14:53   #5 (permalink)
Member: 130995
Thanks Meter: 35,227
@Viking
please, make a small description how this problem was solved, for sure it can be useful for other people.
Old 05-30-2007, 18:38   #6 (permalink)
Viking's Avatar
Member: 19585
Thanks Meter: 19
1. Format FFS
2. Flashing
3. Power On phone
4. Set LNG
5. Voice Prompts ON
6. Power Off phone
7. Power On phone
All work - rings played.
Old 06-16-2007, 12:56   #7 (permalink)
pyjaman's Avatar
Member: 232856
Thanks Meter: 69
hi viking i try your methode but not work for me.
can you explain more please, i have 200 pcs without ringtones ... thank's infinity team for FFS FORMAT button its just to delete fs ...
Old 06-16-2007, 14:01   #8 (permalink)
Viking's Avatar
Member: 19585
Thanks Meter: 19
hm... tested with 3 phones, after all steps rings played
Old 06-16-2007, 14:17   #9 (permalink)
pyjaman's Avatar
Member: 232856
Thanks Meter: 69
tried on 5 phone
1 format ffs
2 full flash ( main and lng)
3 remove battery
4 power on
5 choice lng ( french for me )
6 allow to voice
7 power off
8 power on
9 no ringtone but voice is ok in menu.
need your help please
Old 06-19-2007, 10:24   #10 (permalink)
pyjaman's Avatar
Member: 232856
Thanks Meter: 69
can you tell me wich version and lng used in your method please.
Old 06-22-2007, 13:29   #11 (permalink)
roshantelecom&s's Avatar
Member: 368546
Thanks Meter: 235
how to slove motofone F3 ringtones !!!
hi to all.
ive searched how to slove ringtones probleme after "FFS FORMAT" and after many solution i found this one:
1: FFS format
2: Flash with this versions
Moto-F3_Main_R3T621_G_15.18.12R.A8M
and
Moto-F3_LP_Flex_R3T621_G_15.18.12R_GSDTNGO000HG00165034 _En_Ar.A8P
3: power on with sim card choice lang 1 ( per ex ) set houre ect ...
4: do reset by ***000* and confime with up arrow ( just upside call button )
5: POWER OFF with button, don't remove battery
6: power on and magic, ringtones work.
now your phone work but if you don't want this language pack you can reflash your phone with any version you want ( firmware and language ) but NEVER USE FFS FORMAT...
Old 06-22-2007, 13:30   #12 (permalink)
Member: 368546
Thanks Meter: 235
1000000000 % working
Unlock Motofone F3 ruyramonn Motorola ODM 10 10-19-2007 10:10
Motofone F3 unlocking Possible? dannybz Motorola P2k 5 06-14-2007 16:08
Motofone F3 xavien Motorola P2k 1 02-15-2007 08:53
Motorola Motofone F3 JoAoOpAuLo Infinity-Box 9 01-15-2007 22:27
motofone F3 locked totalmanish Infinity-Box 0 12-24-2006 06:52
Page generated in 0.21747 seconds with 10 queries
