Problem with new CPU 6228!!! 1 Attachment(s) New china phone N999 with CPU 6228 and CM couldn't make FFS FORMAT and Full backup:( This is screen. I made format with usually tool. |
Please, never make screenshot but simply send "operation.log" file to [email protected] Btw, what cable you have used ? Is it was cable based on Infinity-Box (unibox) or other cable ? |
Please, give pinout for N999 ? Very very need. :( HELP! |
Due to a lot of different models with the same name but absolutely different hardware, bottom connectors and different pinouts we recommend you to make detailed description of model, attach phone photo, phone bottom connector photo and information about Gnd and Charge pins on phone bottom connector. After you have this information prepared, please, check the next detailed description how to get pinout for your model: use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle.txt if not helps, please read: http:///vbb/showpo...36&postcount=7 if not helps, please read: http:///vbb/showthread.php?t=433447 |
Connector 2x6 (12 pins) 1 2 3 4 5 6 7 8 9 10 11 12 On USB cable to PC , 1+7- +5V USB, 4 pin - GND, and also 6-pin is GND too. I try any combination from pinout 1.14 from INFINITY program. And model N999 not have in Chinesee miracle on Infinity :( Quote:
4- GND 2- RX 11 - TX |
