09-07-2009, 09:47 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Bulgaria Asenovgrad Age: 42
Member: 239176 Status: Offline Sonork: 100.1602815 Thanks Meter: 851 | problem with nokia n82 im read full flASH before edit languAGE pack after write edited flash file phone phone power but lcd white blink how to solved this br. |
09-07-2009, 10:44 | #2 (permalink) |
Member: 239176 Status: Offline Sonork: 100.1602815 Thanks Meter: 851 | COM6 [VCP0] selected module v2.90 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware editor_corrected_GOLDDRAGON25_GEMINI_PCB01_GPRS_MT 6225_S00.G250_M1_PCB5_DSIM_ST32T4_V04A__fullflash_ 20090906-232705.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:A603:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #02 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #03 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... slowest Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [standard] generation ==================== New firmware detected (v.2.90, database date: 21.08.2009): GOLDDRAGON25_GEMINI_PCB01_GPRS_MT6225_S00.G250_M1_ PCB5_DSIM_ST32T4_V04A.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info protocol ver: 04 ver. sw 1: GOLDDRAGON25_GEMINI_PCB01_GPRS_MT6225_S00.G250_M1_ PCB5_DSIM_ST32T4_V04A.BIN ver. sw 2: G250_M1_PCB5_DSIM_ST32T4_V04A, 00000000 ffs offset/size: 00E00000/00200000 detect device sec info... detection phase #1... . detect device sec info finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... detect device sec info... detection phase #1... . detect device sec info finished startup code area #1 check... startup code area #1 fixed detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: 2088C4FFFFFFFF:2088C400000000 Write: Firmware detect device sec info... detection phase #1... . detect device sec info finished Write Done Finalization ... Finalization Done Finished, time used: 648 sec Remove/Install battery now ! hier log from flash operation not sucess |
09-07-2009, 11:00 | #3 (permalink) |
Freak Poster Join Date: Oct 2008 Location: Pakistan Age: 38
Member: 879956 Status: Offline Thanks Meter: 56 | make the bakup rpl and pm 308 use erase files for flashing then again flash new firmware then its flashed brother his imei will 12345? and write the rpl file and also write pm file wiyh sx4 server ur problem will be slove ... |
09-07-2009, 11:51 | #5 (permalink) |
Member: 239176 Status: Offline Sonork: 100.1602815 Thanks Meter: 851 | after flash with orig readed phone fine worked i cant undertsand where im wrong same problem to nokia n96 after edit white lcd and phone blinking im thinks posoible problem in eeprom after edit |
09-07-2009, 17:13 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If you can restore phone back to life with original full flash backup but problem exist only after language editing please, contact to Language Editor programmer and explain situation, probably he can check this firmware, maybe something wrong was happened with firmware during editing. Here is e-mail of programmer: [email protected] |
09-08-2009, 08:54 | #7 (permalink) |
Member: 239176 Status: Offline Sonork: 100.1602815 Thanks Meter: 851 | phone lcd is still white when im turn to edit in flash cirilic from front menu posoible need orig frimwear with russian and convert russian to bulgarien |
09-08-2009, 21:41 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! send this original firmware to [email protected] he will check why you cant add bulgarian. please write subject "failed to edit to bulgarian" |
problem with nokia 6234 | pachicoo | Universalbox | 2 | 03-29-2010 15:19 |
Pls help with Nokia N82 camera solution | dragnet | Nokia Hardware & Hardware Repair | 6 | 10-07-2009 08:36 |
works with nokia n82 v31.0.016? | chilko | Rebel SIM Card | 1 | 02-03-2009 18:17 |
