03-13-2008, 16:59 | #1 (permalink) |
Freak Poster Join Date: Aug 2004 Location: Egypt
Member: 76228 Status: Offline Sonork: 113105 Thanks Meter: 22 | problem with pinout finder searching adapter at COM10... adapter found, version: 2000 Serial No: *************** pins: 10 power cycles: 1 activation cycles: 10 power control: via adapter power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing...Press and HOLD phone Power button now ! phone can`t power on or do any thing to detecte the pinout i` made all connection that can need it to power on the phone without sucsses.. any idea |
03-13-2008, 18:50 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! it should not power power On in this place. you just push button and keep it pressed while software try to detect pinout. you will see changing numbers in TX/RX window- this means that program is working. all this time power button must remain pressed. |
china cect t818 sucsecssfully format in infinity with auto pinout finder adpter | .::AZEEM::. | Infinity-Box | 2 | 07-02-2009 00:35 |
problem with pin finder. | digitized | Infinity-Box | 47 | 02-14-2009 12:55 |
Problem with Pin Finder Adapter | BouRRi_GSM | Infinity-Box | 14 | 07-18-2008 23:24 |
pinout finder adapter power problem | c_ahmad79 | Infinity-Box | 8 | 05-24-2008 20:02 |
Meet PadFinder - absolutely the best solution for all problems with pinout detection | SHANU | Main Sales Section | 0 | 03-30-2008 05:35 |
