01-20-2016, 21:35 | #1 (permalink) |
Super Moderator Join Date: Jul 2008 Location: Villa del rosario/Nsd Colombia
Member: 813309 Status: Offline Thanks Meter: 1,912 | Problem with plum x230 i have the next problem after format plum x230 via sptools phone dead i read full backup with chinesse miracle to phone full working and after try to flash dead phone get next error Operation : Flash [ v1.40 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 4B0108654D43502020100000028CB117 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 004B , OEM : 0108 [eMMC] : FLASH_INF : [NOT_IN_BASE] , PCM [eMMC] : FLASH_CID : 4B0108654D43502020100000028CB117 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00040000 [eMMC] : FLASH_LEN : 0x00000000ED800000 [eMMC] : FLASH_UCP : 3800 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : a68n , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3700 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000600000-0x0000000000100000 Erase : 0x0000000002300000-0x00000000EA440000 Flash Pre-Erase Done, time used : 00:00:22 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_a68n.bin Preloader Init Failed! Looks like HW error or incompatible image ErrCode : Operation Failed Elapsed: 00:00:44 Reconnect Power/Cable!
__________________ Please do not Personal Message me for help or troubleshooting. They will be ignored. Use the forums! |
