04-01-2018, 15:37 | #1 (permalink) |
Freak Poster Join Date: Feb 2015
Member: 2349228 Status: Offline Sonork: 34610 Thanks Meter: 19 | problem remove frp SnapDragon 210 MSM8x09 i need your help for remove frp VDF511 , 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 0CAD1DBB ID_BLOCK_E : 00040000 ID_BLOCK_L : EED3E281DC4AC97F6BF2958A38E079C5 ID_BLOCK_L : 0B694136E8CFC88D17C0AD2848D9A952 Use CM2 Internal Loader ERROR : Prepare target failed! Unsupported SecureType! INFO : Send log and report.log to support! Include device info also! Reconnect Power/Cable! Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 0CAD1DBB ID_BLOCK_E : 00040000 ID_BLOCK_L : EED3E281DC4AC97F6BF2958A38E079C5 ID_BLOCK_L : 0B694136E8CFC88D17C0AD2848D9A952 Use CM2 Internal Loader ERROR : Prepare target failed! Unsupported SecureType! INFO : Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
04-01-2018, 16:23 | #2 (permalink) |
No Life Poster Join Date: Dec 2015 Location: Somewhere on the Internet
Member: 2500215 Status: Offline Thanks Meter: 417 | ERROR : Prepare target failed! Unsupported SecureType! This should explain your problem... This is not a problem of exe or loaders in exe. It is simply SECURED!!!! If you can get the firmware, Load firmware to flash tab and repeat operation |
The Following User Says Thank You to Southsider2009 For This Useful Post: |
01-21-2019, 10:13 | #4 (permalink) | |
No Life Poster Join Date: Mar 2005 Location: Most Age: 50
Member: 129904 Status: Offline Thanks Meter: 56 | Is there anything new please? Got the same phone. Does anyone idea how to reset FRP? Thanks in advance. Petr Quote:
