problem with Tokyo unlock Problem unlocking Tokyo Orange im using mmodule 2.20 and tried to unlock tokyo orange. everything went fine and software shows the unlock is ok but when i try to use another sim card phone is asking Network Code :confused: is there any issue with firmware version of the phone, please help, searched the forum several times but couldnt find the answer regards |
I have the same problem |
hello guys! we already recieved new firmware readed from New type Tokyo. working under its unlocking, please be little patient |
Hello, Please, download latest MModule from support area (uploaded today) and try to unlock phone again. Waiting for your results. |
COM6 [VCP4] selected Device: Orange-Tokyo Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: unlock unlock method: standard Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6219:8B02:8B01]... CPU: MT6219 CPU: MT6226MA detected chip: 0031:1CC1:4C6A boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.C1FA1 3DA.[DNET26_06A_PCB01_GPRS_MT6226_S01.DS606_332B43_SW_M YWAY_V4_71.BIN_611D8539].rpl identification#1 detection finished device-id: C1FA13DA identification#1 protocol ver: 05 ver. sw1: DNET26_06A_PCB01_GPRS_MT6226_S01.DS606_332B43_SW_M YWAY_V4_71.BIN ver. sw2: DS606_332B43_SW_MyWay_V4.71, C67AE29E ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[DNET26_06A_PCB01_GPRS_MT6226_S01.DS606_332B43_SW_M YWAY_V4_71.BIN]]... file saved: C:\Program Files\InfinityBox\MModule\eeprom[DNET26_06A_PCB01_GPRS_MT6226_S01.DS606_332B43_SW_M YWAY_V4_71.BIN]_20080722-173120.B0E.bin flash: 2088C4FFFFFFFF:2088C400000000 Backup required data Done Patch required data... detection procedure, wait... detection procedure completed Patch required data Done Special operation... detecting additional parameters... ................................... flash: 2088C4FFFFFFFF:2088C400000000 flash: 2088C4FFFFFFFF:2088C400000000 Write: area 0/1 ............................. additional parameters detected Ok buffer management operation active... buffer management operation finished failed buffer management operation active... buffer management operation finished Ok firmware version detected Ok Special operation Done Write... flash: 2088C4FFFFFFFF:2088C400000000 Write: lock-area-4 flash: 2088C4FFFFFFFF:2088C400000000 Write: eeprom Write Done Finalization... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\system_log_C1FA13DA_DNET 26_06A_PCB01_GPRS_MT6226_S01.DS606_332B43_SW_MYWAY _V4_71.BIN_611D8539_20080722-173320.B0X.bin Finished, time used: 201 sec Remove/Install battery now ! Just unlocked this phone with latest modul MModul2.27 works perfect BR |
YES...I have the same problem....i think i need try again tonight.... |
