07-13-2009, 22:05 | #1 (permalink) |
Freak Poster Join Date: Jun 2008
Member: 801936 Status: Offline Thanks Meter: 37 | problem unlock gb 102 module v1.67 Device: LG-GB102 Checking data, wait... Action: unlock read unlock codes Boot ... Press and HOLD Power button now ! error: wrong boot answer #1: Release Power button now Boot Failed Finished, time used: 16 sec Remove/Install battery now ! cable kg 800 |
07-15-2009, 20:25 | #2 (permalink) | |
You need to use KE500 cable ! | |
07-20-2009, 22:34 | #5 (permalink) |
Freak Poster Join Date: Jul 2009 Location: ivory coast
Member: 1072706 Status: Offline Sonork: 100.1623177 Thanks Meter: 26 | slt a tous je recherche la solution pour deblok les HUAWEI T 156 B avec infinity box merci d'avance s'il ya une solution SVP envoyé le mois a cette adresse : [email protected] |
07-20-2009, 23:29 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
The Following 2 Users Say Thank You to InfinitySupport For This Useful Post: |
GB-102 flashing problem | hrocht | VygisToolbox | 0 | 03-26-2010 17:16 |
GB 102 & GB 220 unlock [SOLVED] | woofers | FuriousGold | 28 | 03-13-2010 06:31 |
urgent help to unlock gb 102!!! | andy2012 | LG | 5 | 11-12-2009 15:23 |
Gb 102 & gb 220 | woofers | Z3X-Team Products | 1 | 10-13-2009 11:32 |
lg gb 102 unlocked successfull | delchoni | VygisToolbox | 0 | 07-14-2009 10:32 |
