10-17-2007, 10:08 | #1 (permalink) | ||
Freak Poster Join Date: Mar 2002 Location: bucharest
Member: 9843 Status: Offline Thanks Meter: 2 | se j120 dead because of wrong exe in infinity, i cant repair it now says write error i tried to unlock a se j120i, i opened the shell and selected j120 and the shell opened in fact was moto 02 instead of hmodule , i pressed unlock and program said wrong model selection, saved a backup eeprom and exit saying unknown flash. i realized i had chosen the wrong exe and i opened h module when trying to unlock program said wrong model selection i also tried repair and program said first wrong model selected and then Quote:
thanks | ||
10-17-2007, 16:52 | #2 (permalink) |
Freak Poster Join Date: Jun 2003 Location: Russia, Sevastopol Age: 49
Member: 32504 Status: Offline Thanks Meter: 9 | The same error I have now with Motorola C168 in HModule. But I can flash it by Moto02 with no errors. And I get Writing... ....error: required data not found or unknown eeprom structure Writing Fail When I try to repair or unlock it |
10-17-2007, 17:05 | #4 (permalink) |
Member: 32504 Status: Offline Thanks Meter: 9 | Writing... Area: Firmware flash: 208810FFFFFFFF:20881000000000 Write: Firmware error: error# 000000B0 20:5[01]: Erase fail or program sequence error when set with SR[4,7]. 10:4[01]: Program fail or program sequence error when set with SR[5,7]. error: flash write error: 00000000:00002000 error: error# 000000B0 20:5[01]: Erase fail or program sequence error when set with SR[4,7]. 10:4[01]: Program fail or program sequence error when set with SR[5,7]. error: flash write error: 00000000:00002000 Writing Fail Finished, time used: 21 sec Remove/Install battery now ! The same result on different versions of main from support. |
10-17-2007, 17:11 | #5 (permalink) | |
Member: 32504 Status: Offline Thanks Meter: 9 | COM3 selected Device: Motorola C168 "advanced chip detection" active Action: flash write Write: Firmware Skip: Flex Skip: Language Pack Skip: FFS/File system Skip: Images Skip: Melody Skip: Eeprom Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot Done Check connection... Check connection Done Set baud... Set baud Done Check flash... flash: 208810FFFFFFFF:20881000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb version sw: version sw: Check flash Done Check parameters... reading Motorola C168_eeprom_calibration-1... file saved: backup_Motorola C168_eeprom_calibration-1_20071017-190813.69E.bin Check parameters Done Check data... warning: Probably wrong model selected, Do you want to continue ? Quote:
Check data Done Writing... Area: Firmware flash: 208810FFFFFFFF:20881000000000 Write: Firmware error: error# 000000B2 20:5[01]: Erase fail or program sequence error when set with SR[4,7]. 10:4[01]: Program fail or program sequence error when set with SR[5,7]. 02:1[01]: Block locked during program or erase; operation aborted. error: flash write error: 00000000:00002000 error: error# 000000B2 20:5[01]: Erase fail or program sequence error when set with SR[4,7]. 10:4[01]: Program fail or program sequence error when set with SR[5,7]. 02:1[01]: Block locked during program or erase; operation aborted. error: flash write error: 00000000:00002000 Writing Fail Finished, time used: 23 sec Remove/Install battery now ! Here`s full log | |
10-17-2007, 17:20 | #6 (permalink) |
Member: 32504 Status: Offline Thanks Meter: 9 | Here`s the list of main from support that I tryed to write C168_Main_5-1120-000_2005-Dec-05[1].69M.bin C168_Main_5-1120-000_2005-Dec-05.69M.bin c168_Main_TCT-9-1500-000[1].69M.bin C168_Main_9-1450-000_2006-Jun-01[1].69M.bin C168_Main_7-1340-000_2006-Mar-16.69M.bin C168_Main_5-1340-000_2006-Mar-16.69M.bin |
10-17-2007, 17:29 | #7 (permalink) |
Member: 32504 Status: Offline Thanks Meter: 9 | Now I`ve rewrite the phone by Moto02 with: C168_Flex_1450-031_RUSS_9V18_V1_SE6843AXXU1[1].69F.bin C168_Images_1450-005_T676FB_8V53_V1[1].69G.bin C168_LP_1450-012_T676FJ_8V53_V1_En_Ru_De[1].69P.bin C168_Main_9-1450-000_2006-Jun-01[1].69M.bin C168_Melody_1450-005_T676FB_8V53_V1[1].69G.bin C168_repair_eeprom_03[1].69E.bin After that I tryed to make repair in Hmodule and get the error: COM3 selected Device: Motorola C168 "advanced chip detection" active Action: repair Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot Done Check connection... Check connection Done Set baud... Set baud Done Check flash... flash: 208810FFFFFFFF:20881000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb version sw: 1450-000 version sw: TCT-9- Check flash Done Check parameters... reading Motorola C168_eeprom_calibration-1... file saved: backup_Motorola C168_eeprom_calibration-1_20071017-192609.69E.bin Check parameters Done Check data... Check data Done Writing... ......data prepared Ok flash: 208810FFFFFFFF:20881000000000 Write: eeprom error: error# 000000B0 20:5[01]: Erase fail or program sequence error when set with SR[4,7]. 10:4[01]: Program fail or program sequence error when set with SR[5,7]. error: flash write error: 007F2000:00002000 error: error# 000000B0 20:5[01]: Erase fail or program sequence error when set with SR[4,7]. 10:4[01]: Program fail or program sequence error when set with SR[5,7]. error: flash write error: 007F2000:00002000 error: error# 000000B0 20:5[01]: Erase fail or program sequence error when set with SR[4,7]. 10:4[01]: Program fail or program sequence error when set with SR[5,7]. error: flash write error: 007F2000:00002000 Writing Fail Finished, time used: 26 sec Remove/Install battery now ! |
10-17-2007, 17:50 | #8 (permalink) |
Member: 32504 Status: Offline Thanks Meter: 9 | Something new Log from Moto02 (HModule doesnt write the phone) COM3 selected Device: Motorola C168 Checking data, wait... Action: flash write Write: Firmware Write: Flex Write: Language Pack Write: FFS/File system Write: Images Write: Melody Skip: Eeprom Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 812500 Set Baud Done Check Flash... SW ver: HW ver: Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0020:8810FFFFFFFF flash: ST M58WR064FT, M36D0R6040T0 T 8Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 0020:8810FFFFFFFF flash: ST M58WR064FT, M36D0R6040T0 T 8Mb error: error flash command try#1 to recover erase error#43 Write: Flex flash: ST M58WR064FT, M36D0R6040T0 T 8Mb Write: Language Pack flash: ST M58WR064FT, M36D0R6040T0 T 8Mb Write: FFS/File system flash: ST M58WR064FT, M36D0R6040T0 T 8Mb Write: Images flash: ST M58WR064FT, M36D0R6040T0 T 8Mb Write: Melody flash: ST M58WR064FT, M36D0R6040T0 T 8Mb Writing Done Finished, time used: 324 sec Remove/Install battery now ! |
10-17-2007, 22:41 | #9 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! error: error flash command try#1 to recover erase error#43 this error was recovered after 1 try. in case of fatal error it would give "failed" in the end |
10-18-2007, 07:27 | #10 (permalink) | ||
Member: 9843 Status: Offline Thanks Meter: 2 | ok this is full log: 1. for repair: Quote:
mihai | ||
10-19-2007, 22:51 | #13 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @codec_romania we have found phone with the same flash chip like yours, phone on the way to us. Hope to get it on hands for test in near 2-3 days and prepare update. |
V360 dead because of high voltage ! | jawad8305 | Motorola Hardware Repair | 4 | 01-20-2009 13:49 |
mw930 hardware problem because of wrong flashing. Help me veterans. | aLeN27 | Infineon C16X M51 & ARM7 M52 BASED | 4 | 05-07-2002 08:32 |
do you have a dead a2618/a2618s because of wrong unlock? this might help you! | bglan | Old Ericsson Phones & Sony Phones | 0 | 12-19-2001 10:27 |
