Problem to unlock a Lobster 575? COM2 selected Device: Lobster 575 Checking data, wait... Action: Unlock Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 406250 Set Baud Done Check Flash... Infinity just hangs here? |
Now im getting this COM13 selected Device: Lobster 575 Checking data, wait... Action: Unlock Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0001:227E22212200 flash: Amd S29PL129J,S71PL129JC0,S71PL129JB0,S71PL129JA0 T 8Mb Check Space Done Check Data... file saved: backup_eeprom_20070913-142901.92E.bin please, wait... pass-1... pass-2... Check Data Done Erasing... erase operation not required Erasing Done Writing... Flash: 0001:227E22022201 Err: answer#00 try#1 to recover write error at 01C50000 Err: error checksum try#2 to recover write error at 01C50000 Err: answer#96 try#3 to recover write error at 01C50000 Err: answer#B4 try#4 to recover write error at 01C50000 Err: answer#20 try#5 to recover write error at 01C50000 Err: answer#12 try#6 to recover write error at 01C50000 Err: answer#1F try#1 to recover write error at 01C52000 Err: answer#13 try#2 to recover write error at 01C52000 Err: answer#00 try#3 to recover write error at 01C52000 Err: answer#01 try#4 to recover write error at 01C52000 Err: answer#22 try#5 to recover write error at 01C52000 Err: answer#02 try#6 to recover write error at 01C52000 Err: answer#22 try#1 to recover write error at 01C54000 Err: answer#01 try#2 to recover write error at 01C54000 Err: answer#22 try#3 to recover write error at 01C54000 Err: answer#96 try#4 to recover write error at 01C54000 Err: answer#B4 try#5 to recover write error at 01C54000 Err: answer#20 try#6 to recover write error at 01C54000 Err: answer#12 try#1 to recover write error at 01C56000 Err: answer#1F try#2 to recover write error at 01C56000 Err: answer#96 try#3 to recover write error at 01C56000 Err: answer#B4 try#4 to recover write error at 01C56000 Err: answer#20 try#5 to recover write error at 01C56000 Err: answer#12 try#6 to recover write error at 01C56000 Err: answer#1F try#1 to recover write error at 01C58000 Err: answer#00 try#2 to recover write error at 01C58000 Err: answer#00 try#3 to recover write error at 01C58000 Err: answer#00 try#4 to recover write error at 01C58000 Err: answer#00 try#5 to recover write error at 01C58000 Err: answer#00 try#6 to recover write error at 01C58000 Err: answer#00 try#1 to recover write error at 01C5A000 Err: answer#00 try#2 to recover write error at 01C5A000 Err: answer#00 try#3 to recover write error at 01C5A000 Err: answer#00 try#4 to recover write error at 01C5A000 Err: answer#00 try#5 to recover write error at 01C5A000 Err: answer#00 try#6 to recover write error at 01C5A000 Err: answer#00 try#1 to recover write error at 01C5C000 Err: answer#00 try#2 to recover write error at 01C5C000 Err: answer#00 try#3 to recover write error at 01C5C000 Err: answer#00 try#4 to recover write error at 01C5C000 Err: answer#00 try#5 to recover write error at 01C5C000 Err: answer#00 try#6 to recover write error at 01C5C000 Err: answer#00 try#1 to recover write error at 01C5E000 Err: answer#00 try#2 to recover write error at 01C5E000 Err: answer#00 try#3 to recover write error at 01C5E000 Err: answer#00 try#4 to recover write error at 01C5E000 Err: answer#00 try#5 to recover write error at 01C5E000 Err: answer#00 try#6 to recover write error at 01C5E000 Writing Fail |
hello! please charge battery fully and try again |
Now with power supply on the phone i get this but the phone is still locked COM13 selected Device: Lobster 575 Checking data, wait... Action: Unlock Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0001:227E22212200 flash: Amd S29PL129J,S71PL129JC0,S71PL129JB0,S71PL129JA0 T 8Mb Check Space Done Check Data... file saved: backup_eeprom_20070914-075952.92E.bin please, wait... Err: not locked or unknown eeprom Check Data Fail Finished, time used: 755 sec Remove/Install battery now ! I cant see a Eprom either in the support area? How can this be fixed? |
Are you sure that your phone has sp-lock but not user code lock ? We will prepare repair eerom files ASAP. Also, please, read flash from your phone and send to [email protected] |
Yes this phone is 100% sp locked. Reading flash now. |
Hello, Repair eeprom files for Lobster-575 uploaded in support area. Make eeprom backup from your phone and you can try to use repair eeprom files. |
COM4 [VCP2] selected Device: Lobster 575 Checking data, wait... Action: unlock Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 812500 Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0001:227E22212200 flash: Amd S29PL129J,S71PL129JC0,S71PL129JB0,S71PL129JA0 T 8Mb Check Space Done Check Data... file saved: backup_eeprom_20071022-155431.92E.bin please, wait... pass-1... pass-2... Check Data Done Erasing... erase operation not required Erasing Done Writing... Flash: 0001:227E22022201 Writing Done Finished, time used: 166 sec Remove/Install battery now ! |
