Old 08-04-2009, 23:50   #1 (permalink)
Member: 721725
Thanks Meter: 7
Problem, Unlocking Gtrans N120
Hello.
I have tried to unlock two Gtrans N120, but After process. The SIM isn´t
recognized by the phone.
That´s the opperation log.
I hope someone can help me.
==== log: [04/08/2009 19:00:40] ====
COM11 [VCP0] selected
modulo v2.79
Servicio: Gtran-N120
Checkeando datos, espere...
Habilitada la deteccion avanzada del chip
Action: "sp-unlock"
Metodo unlock: standard
ffs/eeprom backup enabled, it may takes several minutes !
Boot ...
Mantenga Presionado el boton Power !
19200 fixed
Conectando, espere...
Iniciando [6227:8A02:8A01]...
CPU: MT6227
chip: 0031:0F41:1D0C
status: FF
Tamaño del boot packet: 0400
Deje de presionar el boton power ahora !
Boot Done
Iniciar ...
Flash 89881500010001:89881500000000
Flash Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb
numero de flash chip/regiones detectadas: 01/01
Iniciar Done
Seleccionar velocidad ...
115200
Seleccionar velocidad Done
Iniciar bootcode ...
Iniciar bootcode Done
Comprobar la integridad del firmware ...
detect device identification#1...
fase de deteccion #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 detection finished
identification#1 protocol ver: 04
ver. sw 1: KCM_PCB01_GPRS_MT6227_S01.MAUI_06A_W06_44_MP_V20.B IN
ver. sw 2: MAUI.06A.W06.44.MP.V20, 00000000
ffs offset/size: 00E00000/001E0000
detect device identification#2...
detect device identification#2 finished
Estado sim-lock: unknown
Comprobar la integridad del firmware Done
Comprobar el contenido del firmware ...
Comprobar el contenido del firmware Done
Backup de datos requeridos ...
leyendo Gtran-N120_KCM_PCB01_GPRS_MT6227_S01.MAUI_06A_W06_44_MP_ V20__ffs...
Archivo guardado: C:\Archivos de programa\InfinityBox\MModule\Gtran-N120_KCM_PCB01_GPRS_MT6227_S01.MAUI_06A_W06_44_MP_ V20__ffs_20090804-190429.B0E.bin
Backup de datos requeridos Done
Revisión de datos requeridos ...
detection procedure, wait...
detection procedure completed
Revisión de datos requeridos Done
Operacion Especial ...
detecting additional parameters...
Escribir area 0/1
additional parameters detected Ok
Operacion Especial Done
Escribir ...
Escribir eeprom
Escribir Done
Finalizado ...
Finalizado Done
Finalizado, tiempo usado: 457 sec
Quite/coloque la bateria ahora !
==== log: [04/08/2009 19:11:27] ====
modulo v2.79
Action: Leer Codigos
Metodo unlock: read codes
Modelo: Gtran-N120
El Telefono deberia estar APAGADO !
error: No se puede activar el test mode
error: La operación falló !
Finalizado, tiempo usado: 44 sec
==== log: [04/08/2009 19:12:33] ====
modulo v2.79
Action: "sp-unlock"
Boot ...
error: No se puede detectar
En caso de problemas con la conexion inincial: on/off "Autoseleccionar Boot baudrate"
Boot Fail
Finalizado, tiempo usado: 22 sec
Old 08-05-2009, 06:41   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
It may be some problems with N120 unlock, we are trying to fix it now.
Old 08-07-2009, 04:41   #3 (permalink)
Member: 721725
Thanks Meter: 7
Originally Posted by InfinitySupport View Post
Hello,
I hope your help will be quick. I have tow phones broken.
Old 08-07-2009, 08:34   #4 (permalink)
Member: 130995
Hello,
Do you have full flash backup (before unlock) ?
Did you tried to flash phone with firmware from support area ?
Old 08-09-2009, 14:41   #5 (permalink)
Member: 721725
Thanks Meter: 7
Hello,
No, I don´t have the full flash backup before unlock. I have eeprom backup, during unlock. It not working. I tried to flash whith firmware from support area too.
Old 08-09-2009, 18:31   #6 (permalink)
Member: 130995
Hello,
Flash phone with firmware from support area and make format ffs.
Phone should be locked back and it will be able to accept original sim card.
Old 09-11-2009, 00:13   #7 (permalink)
Member: 721725
Thanks Meter: 7
Hello,
I have flashed the phone with all flash files available in the support, and It is locked for all operators yet. the phone don´t accept any SIM card, neither the original SIM card .
I have two phones in this situation, his owners reclaim their phones.
I hope you can found any solution for it, as you promised me some month ago.
regards, Will_traveler
Old 11-05-2009, 00:24   #8 (permalink)
Member: 403517
Thanks Meter: 23
COM7 [VCP0] selected
module v2.92
Device: Gtran-N120
Checking data, wait...
Action: "sp-unlock"
unlock method: standard
Boot ...
19200 fixed
Connecting, wait...
Initializing [6227:8A02:8A01]...
CPU: MT6227
chip: 0031:C141:15B4
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 89881500010001:89881500000000
flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb
Initialize Done
Set baud ...
115200
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is absent
rom info detection finished
rom info protocol ver: 04
address offset: 00000000
ffs address assigned: 00E00000
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: Gtran-N120_KCM_PCB01_GPRS_MT6227_S01.MAUI_06A_W06_44_MP_ V20__ffs...
file saved: C:\Archivos de programa\InfinityBox\MModule\Gtran-N120_KCM_PCB01_GPRS_MT6227_S01.MAUI_06A_W06_44_MP_ V20__ffs_20091104-180841.B0E.bin
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
detecting parameters to apply patch area 1...
error: area 1 can not apply patch
Special operation Done
Write ...
Write: eeprom
Write Done
Finalization ...
Finalization Done
Finished, time used: 303 sec
??? any solution ????
support infinty team?
Old 11-05-2009, 01:27   #9 (permalink)
Member: 130995
Hello,
We want to buy this phone for detailed tests.
Can you sell this phone to us ?
Help Unlock Gtran N120 HECTORTULUA Infinity-Box 20 03-17-2011 15:16
gtran n120 unlock problem ahmertelecom Infinity-Box 10 10-19-2009 09:47
Problems with a GTran N120 hvalero2001 Infinity-Box 4 10-29-2008 20:47
Unlock Gtran N120 jorge1545 Infinity-Box 1 08-11-2008 22:26
Unlock Gtran N120 hvalero2001 Infinity-Box 2 04-20-2008 02:46
Page generated in 0.31861 seconds with 10 queries
