Old 08-13-2008, 16:08   #1 (permalink)
WallfireX's Avatar
Member: 432025
Thanks Meter: 122
How to repair imei pantech c120?
Hi, i need to repair imei pantech c120, i tried with infinity box this show to repair imei but not work, please give a solution
Old 08-13-2008, 16:17   #2 (permalink)
Member: 128745
Thanks Meter: 16,936
what do u mean not work ? what action did you do ? and what result did u get ?
please explain with log files
Old 08-13-2008, 16:24   #3 (permalink)
WallfireX's Avatar
Member: 432025
Thanks Meter: 122
this is log operation:
COM6 [VCP0] selected
Device: Pantech PG-C120
Checking data, wait...
Action: imei repair
Boot...
Phone must be POWERED-OFF !
Cable must be in "GPRS" mode !
Press and HOLD Power button !
Connecting, wait...
Release Power button !
flash: 01227E22212200:9CE59F00000000
flash: Amd S29PL129J,S71PL129JC0,S71PL129JB0,S71PL129JA0 T 8Mb
Boot Done
Set baud...
921600
Set baud Done
Check flash...
Check flash Done
Check space...
Check space Done
Check parameters...
Check parameters Done
Erase...
Erase Done
Write...
Write Done
Finished, time used: 14 sec
Remove/Install battery now !
Imei is the same not repair
Old 08-13-2008, 18:59   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
You must change last 5 imei digits.
Try again and post results
Old 08-14-2008, 20:57   #5 (permalink)
WallfireX's Avatar
Member: 432025
Thanks Meter: 122
nothing, imei it´s the same, not change
Old 08-14-2008, 21:53   #6 (permalink)
Member: 142179
Unhappy pantech ime*************** c-120
hi, i need solution repair imei pantech c120 is urgent please, have 5 phones need of help.
Old 08-15-2008, 16:21   #7 (permalink)
Member: 130995
@WallfireX
What digits you have tried to change ?
@uliko2
just use Infinity-Box and make job
Old 08-15-2008, 16:46   #8 (permalink)
WallfireX's Avatar
Member: 432025
Thanks Meter: 122
I tried to change the last five numbers,
other numbers leave them as shown in the box
Also try to put the IMEI mobile and just change the last five digits and nothing changed
Old 08-18-2008, 18:23   #9 (permalink)
Member: 142179
I have same problem, i changed last five imei digits but not change, please helppppppppp
Old 08-18-2008, 21:07   #10 (permalink)
Member: 130995
What was original imei (last 5 digits) ?
What imei you have tried to write ?
Post here operation log.
pls help--how to repair imei in v3e and k1, imei in both sets are 0000123456 shahi Smart-Clip 1 03-01-2010 09:17
pls help--how to repair imei in v3e and k1, imei in both sets are 0000123456 shahi MSS Box II 0 02-28-2010 15:20
how to repair imei to a lg gb160A?? juvenile Octopus LG/Octoplus LG 1 02-06-2010 12:35
how to repair imei for pantech c120 ?:::ANSWERED::: yorel2202 PolarBox 3 4 04-09-2009 18:47
hi need repair imei Pantech c120 u649 PolarBox 3 1 05-17-2008 23:11
Page generated in 0.20834 seconds with 9 queries
