problem unlocking ke850 COM11 [VCP0] selected Device: LG-KE850 Checking data, wait... Action: unlock direct unlock Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0089:887E Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE850_eeprom-sta_20080818-185850.B1E.bin reading [eeprom-sta2]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE850_eeprom-sta2_20080818-185852.B1E.bin loading data... data loaded imei: 35030526000000100 reading [eeprom-sec_35030526000000100]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE850_eeprom-sec_35030526000000100_20080818-185854.B1E.bin reading [eeprom-complete_35030526000000100]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE850_eeprom-complete_35030526000000100_20080818-185859.B1E.bin backup critical area Done Check memory... Check memory Done Write... Erasing: eeprom-complete Writing: eeprom-complete Verifying... Verify result: 01E2 Done probably you need to restore original imei after unlock process Write Done Finished, Remove/Install battery now ! Time used: 26 sec irestore the imei but not unlocked please help |
backup eeprom then try repair eeprom from support area |
ido repair eeprom from support but the same problem |
i write all the repair eeprom in support but the same problem |
Hello, In some cases it\'s need to flash phone with firmware from support area for unlock. Make flash backup for emergency case and the flash your phone. |
