02-08-2010, 21:29 | #1 (permalink) |
No Life Poster Join Date: Apr 2002 Location: The Green Mile
Member: 11325 Status: Offline Thanks Meter: 266 | pinfinder and OT-660 pinout am posting this here as i need to unlock this one up but not by soldering the pins. I need to use pinfinder 2X5 (L10c) connector. Is there any way as this is brand new and do not want to mark it in any way. thanks |
02-08-2010, 21:36 | #2 (permalink) | |
You can select OT-C701 cable from PinFinder built-in pinout list, OT-660 use the same pinout as C701 | |
02-15-2010, 21:38 | #5 (permalink) |
Member: 11325 Status: Offline Thanks Meter: 266 | ended up using 3 wires soldered to the points as indicated in another thread and unlocked perfectly. Took quite some time (nearly 7 mins) as speed was set to 115k but at the end all was ok . When powered up at the end it just took normal time... there was no need for any 1 minute. Thanks Infinity team once again! Anyway this is the log: COM4 [VCP0] selected module v3.12 Device: Alcatel-660X, 660A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001D03:A00E status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000003:08EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb otp offset: 01FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.30B97 C7D.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN_C368F055].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 30B97C7D rom info ver: 05 sw version: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN project-id: MAUI.06B.W07.28.SP1.V38, 55F068C3 code offset: 00020000 ffs offset/size [01]: 01000000/00FE0000 TCL-ID identification version: 331 provider: 660X-2DTBGB1 customization: CJ33DH04 customization: XJ33DH04 TCL-ID identification done rom info structure: 2nd [enhanced] generation TCL-ID is present ffs/eeprom address assigned: 01000000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is invalid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, part #2) calculation... error: security area (sec info, part #2) header is invalid security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000003:08EA0000000000 flash: 98006F00000003:08EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XJ33DH04 customization name adjusted flash: 98006F00000003:08EA0000000000 flash: 98006F00000003:08EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000003:08EA0000000000 flash: 98006F00000003:08EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XJ33DH04 customization name adjusted flash: 98006F00000003:08EA0000000000 flash: 98006F00000003:08EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000003:08EA0000000000 flash: 98006F00000003:08EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35238703066178 flash: 98006F00000003:08EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000003:08EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-660X,660A_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B _W07_28_SP1_V38__system_log_30B97C7D_C368F055_2010 0215-212651.B0X.bin Finished, time used: 6 min 44 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to Burnt Cobba For This Useful Post: |
02-16-2010, 05:59 | #6 (permalink) | |
Freak Poster Join Date: Aug 2006 Location: Stop WAR on GSM Business
Member: 328416 Status: Offline Thanks Meter: 42 | Quote:
02-16-2010, 10:30 | #7 (permalink) | |
Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 | |
02-16-2010, 22:08 | #8 (permalink) |
Member: 11325 Status: Offline Thanks Meter: 266 | check here for the pin out as kindly member Sajidali clearly explained with his picture attached. http://forum.gsmhosting.com/vbb/showthread.php?t=918633 |
Need Pinout for Alcatel OT 660 - E100 please | ASHRIFF | Infinity-Box | 9 | 11-08-2010 06:47 |
Cant unlock ot-660 by imei calculation!! >>the key is incorrect<< | GSMHEART | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 21 | 11-04-2009 12:02 |
ot 660 / e100 flip unlock not supported | ZIYAAD STRYKER | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 3 | 10-30-2009 10:54 |
how to get provider id IN ALKATEL OT-660 | nilan | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 1 | 09-26-2009 15:25 |
