05-04-2011, 08:35 | #1 (permalink) |
Freak Poster Join Date: May 2004 Location: Proud Serbia
Member: 65352 Status: Offline Thanks Meter: 118 | problem with write operation on chinese miracle v3.30 module v3.30 Device: Autodetect 6228-6268 NAND Checking data, wait... Action: write flash NAND write: Firmware BLACKBERRY_9630_NEOTEL35_08B_GEMINI_PCB01_GPRS_MT6 235B_S01.B300_GH_EN1_TY1G_BE_JSTW_V004__firmware_2 0110503-191215.B4M skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... bootloader version: _BOOTLOADER_B300_GH_EN1_TY1G_BE_JSTW_V004.bin nfi area detection (3 cores) finished: Ok interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0014]: 0098:00D100900015 [TOSHIBA] TC58NVG0S3AFT chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 04000000/04000000 firmware size: 64Mb ffs size: 64Mb detect sec ro... detect custom parameters... detect project-id... project-id: B300_GH_EN1_TY1G_BE_JSTW_V004 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: _BOOTLOADER_B300_GH_EN1_TY1G_BE_JSTW_V004.bin warning: id-page1 area is invalid nfi area detection (0 cores) finished: failed TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: NEOTEL35_08B_GEMINI_PCB01_GPRS_MT6235B_S01.B300_GH _EN1_TY1G_BE_JSTW_V004.BIN project-id: B300_GH_EN1_TY1G_BE_JSTW_V004, 00000000 code offset: 00000000 ffs offset/size [01]: 04000000/04000000 rom info structure: [standard] type (07) TCL-ID is absent ===> done ==================== New firmware found (v.3.30, database date: 17.04.2011): NEOTEL35_08B_GEMINI_PCB01_GPRS_MT6235B_S01.B300_GH _EN1_TY1G_BE_JSTW_V004.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== nfi area detection... bootloader version: _BOOTLOADER_B300_GH_EN1_TY1G_BE_JSTW_V004.bin nfi area detection (3 cores) finished: Ok startup code area #1 check... done number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . write core... error: can not write flash (12): C414:?? error: last error: C414:?? Disconnect... done Finished, time used: 2 min 47 sec Remove/Install battery now ! fullflash was sent to [email protected] phone was good,my job is to translate this unit......but i have problem with write fullflash,always stop as u see in log can u help me Best Regards MADCIRA |
05-04-2011, 19:19 | #3 (permalink) |
Member: 65352 Status: Offline Thanks Meter: 118 | yes even with this from support NEOTEL35_08B_GEMINI_PCB01_GPRS_MT6235B_S01.B300_GH _EN1_TY1G_JST_V005__128m_En_Fr_Es_Dk_Pl_Pt_It_De_M l_Id_Vn_Tr_Ru_Ar_Th_Cn.B4M my backup doesn't help sometimes error 20% sometimes 23%,doesn't stop at same adress already talk with s.Mobi,because i have another MT6235B and LPE doenst load fullflash,i have Error! Language table not found! this is 4-5 MT6235B which i can't translate......my customer wait me for solution,but now with this phone i have problem,dead unit,can't write backup Last edited by MADCIRA; 05-04-2011 at 19:25. |
05-04-2011, 20:30 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! please post your original, not translated backup better if you upload it to RapidShare AG, Cham, Switzerland |
05-04-2011, 21:44 | #5 (permalink) |
Freak Poster Join Date: May 2007 Location: Nic@r@gu@ Age: 41
Member: 516363 Status: Offline Sonork: 100.1601307 Thanks Meter: 35 | konka c612 sim card blocked have try all methods bt phone still locked operation log: COM6 [VCP0] selected module v3.30 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast Unlock procedure can be faster if you skip ffs/eeprom area backup procedure. Do you want to disable ffs/eeprom backup ? ffs/eeprom backup disabled ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:8291:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\InfinityBox\ChineseMiracle\backup_security\id.3 3FEF693.[C612_SAH_PCB01_GPRS_MT6223P_S00.KAA612FM_SAH_SP_EN _FR_1_02_304.BIN_17E6F978].rpl ==================== New firmware found (v.3.30, database date: 17.04.2011): C612_SAH_PCB01_GPRS_MT6223P_S00.KAA612FM_SAH_SP_EN _FR_1_02_304.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished device-id: 33FEF693 rom info ver: 04 sw version: C612_SAH_PCB01_GPRS_MT6223P_S00.KAA612FM_SAH_SP_EN _FR_1_02_304.BIN project-id: KAA612FM_SAH_Sp_En_Fr_1.02.304, 78F9E617 code offset: 00000000 ffs offset/size [01]: 00900000/00700000 rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00900000 standard ffs/eeprom offset confirmed: 00900000 detecting ffs/eeprom size... ffs/eeprom size: 00700000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00900000-00FFFFFF firmware area: 00000000-008FFFFF detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent detecting ffs/eeprom structure pass 1... ..................... ffs/eeprom: detect std location pass #1... .................................... ffs/eeprom: detect ext location pass #1... ................................ ffs/eeprom: detect standard offset pass #1... ffs/eeprom record offset detected ffs/eeprom: detect standard data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok: element #1 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: EC257E25082501:29EA0000000000 Backup required data Done ====> Patch required data ... ................................ lock area found Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: EC257E25082501:29EA0000000000 flash: EC257E25082501:29EA0000000000 Write: lock-area-1 Write Done ====> Finalization ... Finalization Done file saved: C:\InfinityBox\ChineseMiracle\backup_security\C612 _SAH_PCB01_GPRS_MT6223P_S00.KAA612FM_SAH_SP_EN_FR_ 1_02_304__system_log_33FEF693_17E6F978_20110504-143245.B0X.bin Finished, time used: 2 min 22 sec Remove/Install battery now ! |
05-04-2011, 22:03 | #6 (permalink) | |
Member: 516363 Status: Offline Sonork: 100.1601307 Thanks Meter: 35 | Quote:
COM6 [VCP0] selected module v3.30 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast Unlock procedure can be faster if you skip ffs/eeprom area backup procedure. Do you want to disable ffs/eeprom backup ? ffs/eeprom backup disabled ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:8291:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\InfinityBox\ChineseMiracle\backup_security\id.3 3FEF693.[C612_SAH_PCB01_GPRS_MT6223P_S00.KAA612FM_SAH_SP_EN _FR_1_02_304.BIN_17E6F978].rpl ==================== New firmware found (v.3.30, database date: 01.05.2011): C612_SAH_PCB01_GPRS_MT6223P_S00.KAA612FM_SAH_SP_EN _FR_1_02_304.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished device-id: 33FEF693 rom info ver: 04 sw version: C612_SAH_PCB01_GPRS_MT6223P_S00.KAA612FM_SAH_SP_EN _FR_1_02_304.BIN project-id: KAA612FM_SAH_Sp_En_Fr_1.02.304, 78F9E617 code offset: 00000000 ffs offset/size [01]: 00900000/00700000 rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00900000 standard ffs/eeprom offset confirmed: 00900000 detecting ffs/eeprom size... ffs/eeprom size: 00700000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00900000-00FFFFFF firmware area: 00000000-008FFFFF detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent detecting ffs/eeprom structure pass 1... ..................... ffs/eeprom: detect std location pass #1... .................................... ffs/eeprom: detect ext location pass #1... ................................ ffs/eeprom: detect standard offset pass #1... ffs/eeprom record offset detected ffs/eeprom: detect standard data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok: element #1 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: EC257E25082501:29EA0000000000 Backup required data Done ====> Patch required data ... ................................ lock area found Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: EC257E25082501:29EA0000000000 flash: EC257E25082501:29EA0000000000 Write: lock-area-1 Write Done ====> Finalization ... Finalization Done file saved: C:\InfinityBox\ChineseMiracle\backup_security\C612 _SAH_PCB01_GPRS_MT6223P_S00.KAA612FM_SAH_SP_EN_FR_ 1_02_304__system_log_33FEF693_17E6F978_20110504-144505.B0X.bin Finished, time used: 2 min 38 sec Remove/Install battery now ! | |
05-04-2011, 22:10 | #7 (permalink) |
Member: 516363 Status: Offline Sonork: 100.1601307 Thanks Meter: 35 | it was ok but now after turn it off asking for code np im very sorry for this trouble but never happen to me before Last edited by fernando reyes; 05-04-2011 at 22:19. |
05-05-2011, 07:29 | #8 (permalink) |
Member: 65352 Status: Offline Thanks Meter: 118 | @fernando reyes open your thread with problem @InfinityHelp here is orginal backup firmware https://rapidshare.com/files/4606795...503-191215.B4M |
05-05-2011, 16:10 | #9 (permalink) | |
05-07-2011, 12:27 | #12 (permalink) |
Member: 65352 Status: Offline Thanks Meter: 118 | mistery solved another computer without internet connections now I'm waiting s.Mobi to fix Error! Language table not found! in LPE Best Regards MADCIRA |
05-09-2011, 10:13 | #14 (permalink) |
Member: 65352 Status: Offline Thanks Meter: 118 | already tried,speed is not problem...........another computer and normal flashing fix problem,very strange in my country we say feed the dog and don't touch anything na'rani keru i ne diraj nista !!! |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
Operator-Logo for 5110 | MiMiR the WiseMan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-25-1999 15:50 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
