Old 06-06-2010, 16:11   #1 (permalink)
sudsud's Avatar
Member: 420318
Sonork: 100.1661057
Thanks Meter: 65
problem writing imei
dear all
i have a tv mobile c 100 type:bar i can't write imei
here the result after doing write imei mode 3
Action: read/check information
Model: Autodetect 6205-6227 NOR
Checking data, wait...
Phone should be Switched ON !
Connecting, wait...
Phone detected, wait...
Hardware version: AT+ESLP=0
Hardware version: MT6225, E05
Software version: REBOUND25_GEMINI_HW"
Software date: N.V580.Y30
Barcode: 2006.06.14
imei-1: MT0123456789012
imei-2: 356610015231513
imei-3: 350076879418867
Finished, time used: 10 sec
Remove/Install battery now !
any advice??
Old 06-06-2010, 17:59   #2 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,734
Your phone's IMEI-1 seems invalid.
So you can write IMEI by (mode 1).
1st power on phone.
Then write.
Regards .
Old 06-07-2010, 10:52   #3 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
show us logs of IMEI change mode 1,2
Old 06-07-2010, 11:03   #4 (permalink)
sudsud's Avatar
Member: 420318
Sonork: 100.1661057
Thanks Meter: 65
after ffs: safe mode
19200 autodetect
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:F103:000E
status: FF
Connecting at 19200, wait...
Release Power button now !
Hardware: MT6225,E05
Date: 2006.06.14
Version: 1.0
Version: N.V580.Y30M10.0202.08A0812M.1.4D091020G01
Version: REBOUND25_GEMINI_HW
detecting structure #2...
5 11 done
67 byte(s) read
imei: 35007687941886
connection Ok
building list...
done
items to clear: 157
warning: wrong packet cs
items cleared: 157 of 157
building list...
done
items remains: 0
Finished, time used: 30 sec
and genral info:
Connecting, wait...
Hardware version: REBOUND25_GEMINI_HW
Software version: N.V580.Y30M10.0202.0
Software date: 2006.06.14
Barcode: MT012345678901234567
imei-1: 356610015231513
imei-3: 356610015231513
Finished, time used: 15 sec
but no network( EMERGENCY) the info when dailing *#06# is:
IMEI:356610015231513
IMEISV:78
i upload the firmware as:
from alone alone <[email protected]>
to [email protected]
date Sun, Jun 6, 2010 at 7:25 PM
subject new firmware R370M00_PCB01_GPRS_MT6225_S00.N_V580_Y30M10_0202_0 8A0812M_1_4D091020G01.BIN
Old 06-07-2010, 11:17   #5 (permalink)
Member: 148515
hello!
write some working IMEI number, take its value from some old handset
this IMEI can be blacklisted in your country
Old 06-07-2010, 11:30   #6 (permalink)
sudsud's Avatar
Member: 420318
Sonork: 100.1661057
Thanks Meter: 65
Connecting, wait...
imei write method: mode-1
imei write channel: imei #1 for dual sim/mono CPU
new imei-1: 357968005873820
Verification failed !
What to do:
1. Power-Off phone
2. Press software "Write" button
3. Power-On phone
general info after mode 1:
Connecting, wait...
Software version: MT6225, E05"
Software date: REBOUND25_
Barcode: N.V580.Y30M10.0202.08A0812M.1.4D091020G01
imei-1: 2006.06.14"
imei-2: MT0123456789012
Finished, time used: 8 sec
then i made ffs: safe mode again to get the old imei
and here imei change mode 2"
Action: "repair imei"
imei write method: mode-2
new imei: 357968005873820
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
5 11 done
67 byte(s) read
imei: 35661001523151
connection Ok
5 11 done
67 byte(s) read
verification...
verification done: 35796800587382
Finished, time used: 19 sec
then the general info become:
Connecting, wait...
Barcode: 2006.06.14
imei-3: 357968005873820
Finished, time used: 9 sec
Old 06-07-2010, 11:55   #7 (permalink)
sudsud's Avatar
Member: 420318
Sonork: 100.1661057
Thanks Meter: 65
again ffs safe mode:
COM20 [VCP0] selected
module v3.07
Action: reset settings ("format ffs")
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
5 11 done
67 byte(s) read
connection Ok
building list...
done
items to clear: 141
items cleared: 141 of 141
building list...
done
items remains: 0
Finished, time used: 27 sec
general info after ffs:
Connecting, wait...
Finished, time used: 14 sec
then imei write mode 3:
module v3.07
Device: Autodetect 6205-6227 NOR
imei write method: mode-3
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
boot packet size: 0400
Boot Done
====> Initialize ...
flash: 98000300000001:18E59F00000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is absent
rom info detection finished
New firmware detected (v.3.07, database date: 16.01.2010):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
rom info ver: 04
sw version: R370M00_PCB01_GPRS_MT6225_S00.N_V580_Y30M10_0202_0 8A0812M_1_4D091020G01.BIN
project-id: N.V580.Y30M10.0202.08A0812M.1.4D091020G01, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
detecting startup code area #2...
startup code area #2 is absent
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: R370M00_PCB01_GPRS_MT6225_S00.N_V580_Y30M10_0202_0 8A0812M_1_4D091020G01__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\R370M00_PCB01_GPR S_MT6225_S00.N_V580_Y30M10_0202_08A0812M_1_4D09102 0G01__ffs_20100607-134816.B0E.bin
Backup required data Done
====> Patch required data ...
16 step(s) required
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write: ffs
Write Done
====> Finalization ...
Finalization Done
Finished, time used: 7 min 16 sec
general info after imei mode 3:
Connecting, wait...
Barcode: 2006.06.14
still can't change imei??
thank you in advance
little question what IMEISV:78 mean?
Old 06-07-2010, 13:36   #8 (permalink)
sudsud's Avatar
Member: 420318
Sonork: 100.1661057
Thanks Meter: 65
hello, InfinityHelp
did ChineseMiracle" v3.15 update support my firmware??
Old 06-07-2010, 18:26   #9 (permalink)
sudsud's Avatar
Member: 420318
Sonork: 100.1661057
Thanks Meter: 65
my post moved here, sry if post it in wrong section, but i'm still waiting↲BR
Old 06-07-2010, 21:09   #10 (permalink)
Member: 148515
hello!
try to change both IMEIs via bluetooth:
IMEI change without cable over Bluetooth link step-by-step tutorial - GSM-Forum
Old 06-08-2010, 09:05   #11 (permalink)
sudsud's Avatar
Member: 420318
Sonork: 100.1661057
Thanks Meter: 65
oh my G_0_d* ,
dat's perfect , successfully imei changed using blutooth
but the problem still , registration failed , i change many imei s from old handsets
but the result still ( Emergency),, i can search for network manually but can't register ,
i think the phone is locked and need to sp- unlock
i will post the result here of sp- unlock
is it IMEISV:78 ??? what's dat mean?
BIG THANK FOR InfinityHelp
Old 06-08-2010, 12:29   #12 (permalink)
sudsud's Avatar
Member: 420318
Sonork: 100.1661057
Thanks Meter: 65
here general information with pin finder
Model: Autodetect 6205-6239 NOR
Connecting, wait...
Barcode: 2006.06.14
imei-2: 357988025113288
imei-3: 352009025304432
and here with bluetooth com port:
Connecting, wait...
imei-1: 352009025304432
Finished, time used: 5 sec
Again here sp-unlock standard
module v3.15
Device: Autodetect 6205-6239 NOR
Action: "sp-unlock"
unlock method: standard
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
Boot Done
otp offset: 00FE0000
Initialize Done
====> Set baud ...
115200
Set baud Done
TCL-ID is absent
New firmware detected (v.3.15, database date: 06.06.2010):
rom info ver: 04
TCL-ID is absent
ffs/eeprom chip: 00
detecting ffs/eeprom structure pass 1...
ffs/eeprom: detect std location pass #1...
ffs/eeprom: detect standard offset pass #1...
ffs/eeprom record offset detected
ffs/eeprom: detect standard data...
ffs/eeprom record size detected
ffs/eeprom layout detection complete
ffs/eeprom detected ok: element #1
file saved: C:\Program Files\InfinityBox\ChineseMiracle\R370M00_PCB01_GPR S_MT6225_S00.N_V580_Y30M10_0202_08A0812M_1_4D09102 0G01__ffs_20100608-141518.B0E.bin
detection procedure, wait...
detection procedure completed
====> Write ...
Write: ffs
Write Done
Finalization Done
Finished, time used: 12 min 36 sec
then phone genral info using pinfinder:
Connecting, wait...
Barcode: 2006.06.14
imei-2: 352943021391912
imei-3: 352943021391938
also here using bluetooth
Connecting, wait...
imei-1: 352943021391938
still emergency and i tried many imei s
Old 06-08-2010, 18:59   #13 (permalink)
Member: 148515
hello!
can you call 112 number with SIM cards removed?
Old 06-09-2010, 06:39   #14 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,734
Angry
he he he
Emergency mean its have signal problem not IMEI problem!!!
If invalid showing then it is IMEI problem sure..
Best Regards
Old 06-09-2010, 12:55   #15 (permalink)
sudsud's Avatar
Member: 420318
Sonork: 100.1661057
Thanks Meter: 65
Thank you, InfinityHelp and Shakeel_pattoki
when i try 2 call 112 without sim card it give me beeps ( unable to connect)
but with sim card i can search for network manually then the operators in me country appers , when i choose the sim card operator it give me failed to register after a while
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-31-2012 20:09
Nokia 51xx/61xx imei changer ver. 1.10?????? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 04-06-2012 16:22
6110 imei changer !!!!!! Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 11-21-2011 01:44
Page generated in 0.38850 seconds with 9 queries
