shurubelul | 11-20-2007 10:13 | problems with CL75 after full flash i try to write romanian language into CL75 so i write firmware (CL75_100D_Main) +map/customatisation (CL75_Map_DF-M22.10.21F.bin) +language pack with romanian language (CL75_100_LP05L2707_Bg_Fr_De_Ro_Ru.21P.bin)... after that phone work ok (signal, menu icons) bun without sounds, pictures, animations, themes, games, misc...are empty all Code:
Loading file v.01...
CL75_100D_Main.21M.bin loaded
CL75_Map_DF-M22.10.21F.bin loaded
CL75_100_LP05L2707_Bg_Fr_De_Ro_Ru.21P.bin loaded
COM5 [VCP0] selected
Device: Siemens-CL75
Checking data, wait...
Action: Flash write
Write: Firmware
Write: Map/Customization
Write: Language Pack
Skip: Eeprom
Boot...
Press and HOLD Power button !
Connecting, wait...
Release Power button !
flash: 01227E22202200:98E59F00000000
flash: Amd PL127J D 16Mb
Boot Done
Set baud...
460800
Set baud Done
Check Flash...
Check Flash Done
Check space...
Check space Done
Check parameters...
Check parameters Done
Format file system...
area-01...
area requested/selected: 02/03
area-02...
Format file system Done
Write...
Write: Firmware
area requested/selected: 01/03
Write Done
Finished
Remove/Install battery now !
Time used: 2090 sec after this i try to write another version from support area, to make phone usuable like before... Code:
Loading file v.02...
CL75_301D_Main.21M.bin loaded
CL75_301_LP1-L29.02_Catalan_Fr_De_Gr_It_Pt_Br_Es_Tr.21P.bin loaded
Action: Flash write
Write: Firmware
Skip: Eeprom
Boot...
Connecting, wait...
Boot Done
Set baud...
460800
Set baud Done
Check Flash...
Check Flash Done
Check space...
Check space Done
Check parameters...
area-01...
area-02...
Write...
Write: Firmware
Write Done
Finished
Time used: 2326 sec now phone have signal, sounds but in menu, icons are not opening when i try to enter in submenu, only contacts responde...
after that i try with another version: Code:
CL75_600D_Main.21M.bin loaded
CL75_600_LP91-L29.05_Fr_De_It_Ru_Es.21P.bin loaded
Action: Flash write
Write: Firmware
Skip: Eeprom
Boot...
Connecting, wait...
Boot Done
Set baud...
460800
Set baud Done
Check Flash...
Check Flash Done
Check space...
Check space Done
Check parameters...
area-01...
area-02...
Write...
Write: Firmware
Write Done
Finished
Time used: 2098 sec phone is without signal, verry slow in menu, white display from time to time when i scroll menu icons, not responding...
PHONE WORK OK BEFORE, I`M VERY SURE... |
