04-09-2010, 16:58 | #1 (permalink) |
Freak Poster Join Date: May 2008
Member: 772508 Status: Offline Thanks Meter: 16 | Problems with some alcatel models after unlock here is the log of the operations: second time: back label OT-360 TCT MOBILE N 26C 9YAB 11 CMS HECHO EN CHINA FCC ID:RAD104 360A-2ACEC03 COM4 [VCP1] selected module v3.32 Device: Alcatel-360A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:BDEA:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:2BEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.C8 4F01D0.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN_481CB0D4].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: C84F01D0 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN project-id: MAUI.08A.W08.36.SP1.V9, D4B01C48 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 26C provider: 360A-2ACECO3 customization: CI26NO31 customization: XI26NO31 TCL-ID identification done rom info structure: 2nd [enhanced] generation TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: disabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XI26NO31 customization name adjusted flash: EC240200000000:2BEA0000000000 flash: EC240200000000:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: EC240200000000:2BEA0000000000 flash: EC240200000000:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: FFFFFFFFFFFFFF flash: EC240200000000:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC240200000000:2BEA0000000000 Finalization Done file saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\Alcat el-360A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08 _36_SP1_V9__system_log_C84F01D0_481CB0D4_20100405-195949.B0X.bin Finished, time used: 2 min 3 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! and the phone returned, here is the log of today: COM4 [VCP0] selected module v3.34 Device: Alcatel-360A Checking data, wait... advanced flash detection enabled Action: rebuild security area enhanced security fix enabled ====> Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:BDEA:A00C status: 01 high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:2BEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.C8 4F01D0.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN_481CB0D4].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: C84F01D0 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN project-id: MAUI.08A.W08.36.SP1.V9, D4B01C48 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 26C provider: 360A-2ACECO3 customization: CI26NO31 customization: XI26NO31 TCL-ID identification done rom info structure: 2nd [enhanced] generation TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: disabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XI26NO31 customization name adjusted flash: EC240200000000:2BEA0000000000 flash: EC240200000000:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................region counter set: 01 security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: EC240200000000:2BEA0000000000 flash: EC240200000000:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: FFFFFFFFFFFFFF flash: EC240200000000:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC240200000000:2BEA0000000000 Finalization Done file saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\Alcat el-360A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08 _36_SP1_V9__system_log_C84F01D0_481CB0D4_20100409-104207.B0X.bin Finished, time used: 2 min 12 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! BR. |
04-10-2010, 23:19 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, To be honest we have no information about this problem, it was no any such problems before. We will try to check what may be wrong. Please, keep us informed about situation with your phones. |
04-13-2010, 00:13 | #5 (permalink) |
Member: 772508 Status: Offline Thanks Meter: 16 | here some pics of the phone when is locked for all networks today i uninstalled infinity and reinstall InfinitySetupMain_v2.18a i will unlock the phone again and will inform after 3 days i dont find edit to edit my previus post. pd: this is the 360 and here is the log, i used MModule_v3.23 because a friend tellme that with this module the phone will not return locked. COM4 [VCP0] selected module v3.23 Device: Alcatel-360A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:BDEA:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:2BEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.C8 4F01D0.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN_481CB0D4].rpl rom info detection finished device-id: C84F01D0 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN project-id: MAUI.08A.W08.36.SP1.V9, D4B01C48 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 rom info structure: 2nd [enhanced] generation TCL-ID is absent ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: disabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is invalid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, part #2) calculation... identification header detected customization: XI26NO31 customization name adjusted flash: EC240200000000:2BEA0000000000 flash: EC240200000000:2BEA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: EC240200000000:2BEA0000000000 flash: EC240200000000:2BEA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: FFFFFFFFFFFFFF flash: EC240200000000:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC240200000000:2BEA0000000000 Finalization Done file saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\Alcat el-360A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08 _36_SP1_V9__system_log_C84F01D0_481CB0D4_20100412-182234.B0X.bin Finished, time used: 2 min 53 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! Last edited by fermetal; 04-13-2010 at 00:22. |
04-13-2010, 00:17 | #6 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Bogotá Colombia Age: 43
Member: 150844 Status: Offline Thanks Meter: 309 | Yes im faced same problem on ot360a and ot383a,After imei change and unlock phone working fine, but phones became locked sometime later. Im doing only imei repair whitout unlock but still the same. Please check it. |
04-13-2010, 16:44 | #9 (permalink) | |
Member: 772508 Status: Offline Thanks Meter: 16 | Quote:
about the 303 the client was angry and he took the phone and asked for their money. PD. in this moment i have in my hands the 360. im waiting the third day. BR.. | |
04-13-2010, 21:16 | #10 (permalink) |
Insane Poster Join Date: Apr 2010 Location: Ivory cost Age: 38
Member: 1276144 Status: Offline Sonork: good leaner Thanks Meter: 9 | I receive Ot-303 relock, after unlock . i just format phone with new alcatel format methode ( *#power ) and work fine , since he no come then i think it's work . |
The Following User Says Thank You to pral For This Useful Post: |
04-20-2010, 17:54 | #13 (permalink) |
Member: 772508 Status: Offline Thanks Meter: 16 | 3 days and i have the phone again in my hands locked....... the same problem the same phone INFINITY SUPPORT PLEASE HELP !!!!!!!!!!!!!!!!! IM NOT THE ONly one with this problem !!!!!!!!!!!!! |
04-20-2010, 20:01 | #14 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, Yes, we are trying to fix it. The problem is that the problem appear not right after operation., but in some time, so it's quite hard to make detailed tests. |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
