11-16-2020, 22:30 | #1 (permalink) |
Junior Member Join Date: Sep 2020 Location: Maputo, Mozambique
Member: 2967320 Status: Offline Thanks Meter: 6 | Process Failed 62 order failure. Cm2 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.09 Load IDBase v8331 Ok! Operation : SP Unlock [ v2.09 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... >>> Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : SP Unlock [ v2.09 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... >>> Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : SP Unlock [ v2.09 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : VDC_ZA_P731K30V1.0.0B06 Platform Version: MOCORTM_17C_W18.41.3_P13_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_W18.41.3_P13 HW Version: sc7731e_modem CMP_Time : 03-04-2019 14:15:17 MODEM TAG : MOCORTM_17C_W18.41.3_P13_Debug_FM_BASE_17C_W18.41. 3_P13_sc7731e_modem_pike2_pub NVMng : SecurityInfo IMEI[1] : 861486040557190 IMEI[2] : 867400020316620 WIFIMAC : 60146698EE94 BT_MAC : 4859A473D77E SEC : SLS:2, SKS:0, SKV:4 SLStatus : 2C Status : Locked! Server unlock required! Connecting to server... Connected Authenticating... Authenticated Checking Client version... Client version Ok Process... Process faled: 62 order failure Reconnect Power/Cable! |
11-16-2020, 22:48 | #2 (permalink) |
Member: 1043909 Status: Online Thanks Meter: 60,926 | Hello, Please use http://translate.google.com if you do not understand the text You was approved as tester several hours ago. After that you contacted to support by e-mail and test activation was removed as per your request. Do you wan to be be a tester again ? |
