08-06-2015, 10:17 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: In My Limit
Member: 610502 Status: Offline Sonork: 100.1618428 Thanks Meter: 161 | Q Mobile A300 6572 EMMC Phone Book Extraction Failed Need Solution.. I have a Q Mobile A300 hang on logo customer was insisting for his Contacts no matter how much contacts i tried but the results is given under... LOGS: Card found: S/N Chinese Miracle II [MTK module] v 1.25 Operation : Check / Read Info [ v1.25 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 27 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164048601A3EC4D4125 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164048601A3EC4D4125 [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : QMobile ProdName : A300 ProdModel : QMobile A300 Device : QMobile A300 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1.P65 Done! Elapsed: 00:00:17 Reconnect Power/Cable! Operation : Read UserData [ v1.25 ] PhoneBook : Enabled 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 27 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164048601A3EC4D4125 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164048601A3EC4D4125 [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Step #1 Operation Failed Elapsed: 00:00:12 Reconnect Power/Cable! |
08-06-2015, 10:41 | #3 (permalink) | |
Member: 610502 Status: Offline Sonork: 100.1618428 Thanks Meter: 161 | Thanks jayDI Sir but.. Quote:
Any other or further suggestion or solution? waiting for reply.. Sheraz... | |
08-06-2015, 11:43 | #6 (permalink) | |
Member: 610502 Status: Offline Sonork: 100.1618428 Thanks Meter: 161 | Thanks For Fast reply.. Quote:
Thanks for understanding my problem...and for improving the Great infinity Box..... One More Interesting fact after backup all files i format the set with zero format UDA+Cache but set hang at logo i waited for 10 minutes but nothing happen.... B/R Sheraz...... Last edited by BISMILLAH MOBILES; 08-06-2015 at 11:48. | |
08-06-2015, 11:47 | #7 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | No, need not scatter, need full dump. With it can determine problem and find the way. |
08-06-2015, 11:52 | #8 (permalink) |
No Life Poster Join Date: Sep 2006 Location: ---> Hope
Member: 355782 Status: Offline Thanks Meter: 1,265 | upload only *.ispff file and dont forget to compress before uploading. If you face any problem come to me as you know I have 7x faster internet than you... wBw, Nasir Javed |
The Following User Says Thank You to Nasir Mobiles For This Useful Post: |
