Q Mobile A6 Tested Firmware :( Salaam i have QMobile A6 sim managment is hide i try to flash with many file download from hosting and other link now phone is dead any one have tested Firmware pls share with me Thanks :) |
Hare is logs :) Hare is logs 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital Boot Ok! BB_CPU_PID : 6575 BB_CPU_NME : [MediaTek] MT6575|MT6577_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0xE201 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x84 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , HYNIX [eMMC] : FLASH_CID : 90014A2058494E594815A13A7960CFFF [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 086FAB87ABFFAE0ADF50B5545D554198 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6577 , Project : MTK6577 , Storage : eMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled Switching to HSUSB HSUSB Init Ok BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : Old Dedvice , skip BatteryLevel check BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000040000-0x0000000000620000 Erase : 0x0000000000D80000-0x0000000061964000 Flash Pre-Erase Done, time used : 00:00:09 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_s8070.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0012 Update PMT by user request Repartition Done! Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : EBR2 Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:11:23 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : EBR2 Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:36 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:12:32 |
Have any one tested firmware if tested FW have pls share with us :) |
file is ok but baseband problem and hide sim mangement i flashed many files but hid sim mangement not solve |
use the correct title bro |
@Jazigul Respect others KGM-peshawar said right U wrote wrong title for ur thread.For ur Information there is 2 diffrent hardrware in A6. (1)A6 Single core (2)A6 Dual core. |
Your phone is DUAL CORE. |
i flash qmobile a6 but after hide sim mangement please any body help |
Brand : Qmobile ProdName : s8070 ProdModel : A6_S8070B Device : s8070 AndroidVer: 4.0.4 MTKxCPU : MT6575 MTKxPRJ : ALPS.ICS.MP.V2.3 MT6575__Qmobile__A6_S8070B__s8070__4.0.4__ALPS.ICS .MP.V2.3 - Download - 4shared - ghani bilal |
Its simple See one post above u GSM KPK share A6 file but with mtk6575 which is single core.and ur set have MTK 6577.isn,t it simple. |
Allrady i try this FW Bro Also now this phone not pick driver for Flashing |
@Jazigul dont try MTK6575 single core file.Search Factory file for DUAL CORE and flash.if set not connect that means dead boot now u need open phone and find Kcolo point then u can flash again with corect file. |
