q mobile e 900 dead after flash hello mat q mobile e 900 touch problem i format but same first i make backup then i flash with backup file mobile is not on before this opration mobile is on now mobile not on please help here log COM5 [VCP0] selected module v4.12 Device: _Autodetect MT6228-6268 NAND Checking data, wait... Action: write flash NAND write: Firmware TINNO35_09A_PCB01_GPRS_MT6235B_S01.E930_MP_F1_PK_B B5E_V34_12__firmware_20110917-152628.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... bootloader version: TINNO35_09A_BOOTLOADER_V005_MT6235B_E930_MP_F1_PK_ BB5E_V34_12.bi nfi area detection (3 cores) finished: Ok interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (460800)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... detect custom parameters... detect project-id... project-id: E930_MP_F1_PK_V34_07 detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: TINNO35_09A_BOOTLOADER_V005_MT6235B_E930_MP_F1_PK_ V34_07.bin nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... startup code area #1 is invalid startup code area #1 detection done rom info ver: 07 sw version: TINNO35_09A_PCB01_GPRS_MT6235B_S01.E930_MP_F1_PK_V 34_07.BIN project-id: E930_MP_F1_PK_V34_07, 85120C21 code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent ===> done nfi area detection... bootloader version: TINNO35_09A_BOOTLOADER_V005_MT6235B_E930_MP_F1_PK_ BB5E_V34_12.bi nfi area detection (3 cores) finished: Ok startup code area #1 check... rpl file not found: c:\InfinityBox\MModule\id.00006235.[TINNO35_09A_PCB01_GPRS_MT6235B_S01.E930_MP_F1_PK_B B5E_V34_12.BIN_CE267B07].rpl rpl file not found: c:\InfinityBox\MModule\id.00006235._TINNO35_09A_PC B01_GPRS_MT6235B_S01.E930_MP_F1_PK_BB5E_V34_12.BIN _CE267B07_.rpl rpl file not found: c:\InfinityBox\MModule\backup_security\id.00006235 .[TINNO35_09A_PCB01_GPRS_MT6235B_S01.E930_MP_F1_PK_B B5E_V34_12.BIN_CE267B07].rpl rpl file not found: c:\InfinityBox\MModule\backup_security\id.00006235 ._TINNO35_09A_PCB01_GPRS_MT6235B_S01.E930_MP_F1_PK _BB5E_V34_12.BIN_CE267B07_.rpl ==================== warning: unknown firmware: TINNO35_09A_PCB01_GPRS_MT6235B_S01.E930_MP_F1_PK_B B5E_V34_12.BIN_CE267B07 Unknown firmware found (v.4.12, database date: 21.02.2012), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: TINNO35_09A_PCB01_GPRS_MT6235B_S01.E930_MP_F1_PK_B B5E_V34_12.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed You can flash phone now but can not finalize it, in most cases phone CAN NOT power-on. Do you want to continue anyway ? number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . . . write core... Disconnect... done Finished, time used: 14 min 46 sec Remove/Install battery now ! |
hello! post this firmware, i will convert it for you |
TINNO35_09A_PCB01_GPRS_MT6235B_S01.E930_MP_F1_PK_V 34_07__firmware_20120502-173021.B4M.bin |
