04-28-2016, 13:27 | #1 (permalink) |
Freak Poster Join Date: Nov 2011 Location: karachi
Member: 1686673 Status: Offline Thanks Meter: 53 | Q mobile K150 SPD 6531A Flash FIle Read By infinity Box CM2 Assalam O Alaikum Friends Here Is Q mobile K150 SPD 6531A Flash File Read By Infinity Box CM2 Download |
The Following 3 Users Say Thank You to Khan-jee For This Useful Post: |
08-11-2016, 15:35 | #4 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | try boot key send key -* -home - back key for better result use Boot cable read doc folder ( make boot cable in 2 minute) |
The Following 2 Users Say Thank You to syed tuqeer For This Useful Post: |
02-27-2017, 09:04 | #6 (permalink) |
No Life Poster Join Date: Oct 2013 Location: MajeedGsm
Member: 2046498 Status: Offline Sonork: 100.1676751 Thanks Meter: 162 | Tested Boot Key boot key press and hold menu key+* key insert cable FastCheck : SPD65xx Load file... Not found any ExtInfo data (Compressed already) Load Ok Operation : Flash [ v1.16 ] ======= Flash Files set for flashing : [ MCU ] : SPD6531_00400000_GD25LQ32_en__1.0-k150.bin 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 15 ] Port Opened Sync... Initial Boot Failed! Reconnect Power/Cable! Operation : Flash [ v1.16 ] ======= Flash Files set for flashing : [ MCU ] : SPD6531_00400000_GD25LQ32_en__1.0-k150.bin 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 15 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 ======= Flashing MCU Mapping file ... Mapping done Processing file : SPD6531_00400000_GD25LQ32_en__1.0-k150.bin Init ok, send data Flashing Done! Info : In some cases after flash required make "Format Fs / Reset Phone" Done! Elapsed: 00:01:34 Reconnect Power/Cable! |
01-23-2018, 18:06 | #10 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Dear Sirs, If you have good flash files and if you want to share it with other users please use IOS File Uploader Tool Please do not upload password protected or damaged files, all of them will be deleted after upload. Thank you ! |
