11-25-2015, 10:52 | #1 (permalink) |
Freak Poster Join Date: Mar 2014 Location: GSM WORLD
Member: 2140248 Status: Offline Thanks Meter: 166 | Q Mobile X500 MT6582 Virus Problem I Have Q Mobile X500 MT6582 in Virus Problem I have Try With Smart AV 1st Time Software Show 13 infected Files Code: Start at : [11/25/2015 / 2:31:48 PM] Operation : Format FileSystem [ v1.37 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 Error : DA init Failed! Error code : 0x1 LErr : 0000 Boot Error! Operation Failed Elapsed: 00:00:15 Reconnect Power/Cable! Finish at : [11/25/2015 / 2:32:03 PM] Start at : [11/25/2015 / 2:32:12 PM] Operation : Remove Viruses [SmartAV] [ v1.37 ] SmartAV Conf : 100/75/4000 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3758564D42019D8DD43A5199 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMVX7 [eMMC] : FLASH_CID : 1501004B3758564D42019D8DD43A5199 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 13 Removing infected files and scripts ... SmartAV Report : Removed 13 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #2 : PostFix Ok! Done! Done! Elapsed: 00:01:10 Reconnect Power/Cable! Finish at : [11/25/2015 / 2:33:23 PM] Code: Start at : [11/25/2015 / 2:37:18 PM] Operation : Remove Viruses [SmartAV] [ v1.37 ] SmartAV Conf : 100/75/4000 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3758564D42019D8DD43A5199 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMVX7 [eMMC] : FLASH_CID : 1501004B3758564D42019D8DD43A5199 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 7 Removing infected files and scripts ... SmartAV Report : Removed 7 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #2 : PostFix Ok! Done! Done! Elapsed: 00:00:52 Reconnect Power/Cable! Finish at : [11/25/2015 / 2:38:10 PM] |
11-25-2015, 12:42 | #5 (permalink) | |
No Life Poster Join Date: Jan 2009 Location: JESSORE, BNGLADESH. Age: 39
Member: 939797 Status: Offline Sonork: 100.1601089 Thanks Meter: 359 | Quote:
Limit=100 LOF=80 Sense=1000 Yes can try. And don't forget to revert back settings after operation as best setting is already configured. | |
11-25-2015, 13:41 | #8 (permalink) |
No Life Poster Join Date: Nov 2008 Location: pakistan
Member: 898041 Status: Offline Sonork: 100.1593459 Thanks Meter: 549 | i have same problem in qmobile i6 after smart av and full reset phone in same condition. plz infinity team update the smart av in next update. |
