Q mobile xli andriod 8.0 not supported it always says not responding Set mode to : SP [SC773x] eMMC [Android 6.x] Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 6 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Lost connection with Target! Boot failed! Reconnect Power/Cable! Set mode to : SP [SC773x] eMMC [Android 7.x] Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 8 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Lost connection with Target! Boot failed! Reconnect Power/Cable! Set mode to : SP [SC773x] eMMC [Generic 4.x-5.0] Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 8 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Lost connection with Target! Boot failed! Reconnect Power/Cable! Set mode to : SP [SC773x] eMMC [Android 7.x] Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert battery back 2. Insert cable 3. In case of SVC init problems - connect with hold "VolDown" button! ==== Wait for phone... Phone found! [ 8 ] Port Opened Sync... InitSvc Done Wait for phone... Sync... Phone Initial Info : Platform : MOCORTM_17C_W18.21.1_Debug Project : pike2_pub HWInfo : sc7731e_modem Phone Security Info : IMEI [1] : 090050084A35857 IMEI [2] : 095050089000000 BT_ADDR : 000000000000 SelfInfo : BatVoltage : 3.404 V Done Reconnect Power/Cable! |
All 8x SPD phones now use RSA signed loaders, so existing packages in CM2SPDv1x line will NOT work. Will work ONLY signed for this device factory FW as base. We will rollout SPd with some features in near days. Stay tuned. |
hmmm can i format this unit in sev mode ? without any risk ? |
SVC mode will just reset userdata. FRP will left. |
