10-26-2020, 07:48 | #1 (permalink) |
No Life Poster Join Date: Mar 2011 Location: Faisalabad
Member: 1527968 Status: Offline Sonork: 100.1651182 Thanks Meter: 483 | q smart x10 boot problam ExtSparse : Enabled ForceRead : Disabled 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM11) MODE : PRELOADER PORT PORT : 11 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 CODE : Zion TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : Wiko : SEC_6739 | Manual : Disabled BROM : SOCID : 117EC08721E89E54253F8430723E3836D206BA6F1A582DFD9B F489E963C81003 AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007024 : DA SEND ERROR! ERROR : SECURE BOOT : SELECTED DA NOT SUPPORTED IN CURRENT DEVICE STATE! INFO : PRELOADER Level : Connect device in BROM mode! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Read Firmware [ v2.16 ] ExtSparse : Enabled ForceRead : Disabled 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM13) MODE : BOOTROM PORT : 13 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 CODE : Zion TYPE : MODERN RAPHAEL BROM : MEID : 02B36942B93C2C50E989A3042FA28EF4 BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Wiko : SEC_6739 | Manual : Disabled BROM : SOCID : 117EC08721E89E54253F8430723E3836D206BA6F1A582DFD9B F489E963C81003 AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0008 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : BOOT 2ND DA FAILED! ERR : 0xC0070004 ERR : DA_HASH MISMATCH Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.16 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM11) MODE : PRELOADER PORT PORT : 11 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 CODE : Zion TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : TECNO : SECURE_v2 | Manual : Disabled BROM : SOCID : 117EC08721E89E54253F8430723E3836D206BA6F1A582DFD9B F489E963C81003 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SWSEC.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007024 : DA SEND ERROR! ERROR : SECURE BOOT : SELECTED DA NOT SUPPORTED IN CURRENT DEVICE STATE! INFO : PRELOADER Level : Connect device in BROM mode! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.16 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM11) MODE : PRELOADER PORT PORT : 11 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 CODE : Zion TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : TECNO : G70[G80][G90] | Manual : Disabled BROM : SOCID : 117EC08721E89E54253F8430723E3836D206BA6F1A582DFD9B F489E963C81003 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_G7xG8xG9x.bin AGENT : Selected AGENT doesn't have required configuration! >>> Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! Operation : Identify [ v2.16 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM11) MODE : PRELOADER PORT PORT : 11 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 CODE : Zion TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : TECNO : LB6 | Manual : Disabled BROM : SOCID : 117EC08721E89E54253F8430723E3836D206BA6F1A582DFD9B F489E963C81003 AGENT : Look for suitable BootChain in DA ... AGENT : DA_SWSEC.bin AGENT : Selected AGENT doesn't have required configuration! >>> Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! Operation : Identify [ v2.16 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM11) MODE : PRELOADER PORT PORT : 11 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 CODE : Zion TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : INFINIX : SECURE_BASE | Manual : Disabled BROM : SOCID : 117EC08721E89E54253F8430723E3836D206BA6F1A582DFD9B F489E963C81003 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SWSEC.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007024 : DA SEND ERROR! ERROR : SECURE BOOT : SELECTED DA NOT SUPPORTED IN CURRENT DEVICE STATE! INFO : PRELOADER Level : Connect device in BROM mode! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.16 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM11) MODE : PRELOADER PORT PORT : 11 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 CODE : Zion TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : 0_base : MT6570_v1728_REPAIR | Manual : Disabled BROM : SOCID : 117EC08721E89E54253F8430723E3836D206BA6F1A582DFD9B F489E963C81003 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_6570.bin AGENT : Selected AGENT doesn't have required configuration! >>> Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! Operation : Identify [ v2.16 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM11) MODE : PRELOADER PORT PORT : 11 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 CODE : Zion TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : INFINIX : SEC_NEW | Manual : Disabled BROM : SOCID : 117EC08721E89E54253F8430723E3836D206BA6F1A582DFD9B F489E963C81003 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007024 : DA SEND ERROR! ERROR : SECURE BOOT : SELECTED DA NOT SUPPORTED IN CURRENT DEVICE STATE! INFO : PRELOADER Level : Connect device in BROM mode! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.16 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM13) MODE : BOOTROM PORT : 13 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 CODE : Zion TYPE : MODERN RAPHAEL BROM : MEID : 02B36942B93C2C50E989A3042FA28EF4 BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v1952 | Manual : Disabled BROM : SOCID : 117EC08721E89E54253F8430723E3836D206BA6F1A582DFD9B F489E963C81003 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0008 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : BOOT 2ND DA FAILED! ERR : 0xC0070004 ERR : DA_HASH MISMATCH Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.16 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM11) MODE : PRELOADER PORT PORT : 11 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 CODE : Zion TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : 0_base : BASE_v1944 | Manual : Disabled BROM : SOCID : 117EC08721E89E54253F8430723E3836D206BA6F1A582DFD9B F489E963C81003 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007024 : DA SEND ERROR! ERROR : SECURE BOOT : SELECTED DA NOT SUPPORTED IN CURRENT DEVICE STATE! INFO : PRELOADER Level : Connect device in BROM mode! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.16 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM13) MODE : BOOTROM PORT : 13 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 CODE : Zion TYPE : MODERN RAPHAEL BROM : MEID : 02B36942B93C2C50E989A3042FA28EF4 BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v1944 | Manual : Disabled BROM : SOCID : 117EC08721E89E54253F8430723E3836D206BA6F1A582DFD9B F489E963C81003 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! DA : EMI : Failed to get EMI info from selected source! DA : BOOT to 2nd DA ... DA : BOOT 2ND DA FAILED! ERR : 0xC0070004 ERR : DA_HASH MISMATCH Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.16 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM11) MODE : PRELOADER PORT PORT : 11 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 CODE : Zion TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : 0_base : BASE_v1944 | Manual : Disabled BROM : SOCID : 117EC08721E89E54253F8430723E3836D206BA6F1A582DFD9B F489E963C81003 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007024 : DA SEND ERROR! ERROR : SECURE BOOT : SELECTED DA NOT SUPPORTED IN CURRENT DEVICE STATE! INFO : PRELOADER Level : Connect device in BROM mode! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.16 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM13) MODE : BOOTROM PORT : 13 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 CODE : Zion TYPE : MODERN RAPHAEL BROM : MEID : 02B36942B93C2C50E989A3042FA28EF4 BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v1944 | Manual : Disabled BROM : SOCID : 117EC08721E89E54253F8430723E3836D206BA6F1A582DFD9B F489E963C81003 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! DA : EMI : Failed to get EMI info from selected source! DA : BOOT to 2nd DA ... DA : BOOT 2ND DA FAILED! ERR : 0xC0070004 ERR : DA_HASH MISMATCH Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
