07-15-2016, 07:09 | #1 (permalink) |
No Life Poster Join Date: Oct 2007
Member: 608516 Status: Offline Sonork: 100.1607007 Thanks Meter: 123 | lenovo a328 dead after flash here is log 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040503A2FED9A121 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040503A2FED9A121 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : ED3A4A45E4EA410BCE10CC4EC1FF6412 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Info read not done Erased phone or unsupported FlashIc? Done! Elapsed: 00:00:07 Reconnect Power/Cable! |
10-13-2016, 05:33 | #5 (permalink) |
Junior Member Join Date: Apr 2015 Location: Cagayan de Oro City. Phils
Member: 2374775 Status: Offline Thanks Meter: 4 | re: lenovo a328 dead after flash i got the same problem. all went well the flashing OK using SP Flash tool, but phone is still dead. i have tried firmwares A328 ROW_S322; A328 ROW_S324; A328 ROW_S325; A328 ROW_S326; A328 ROW_S327 but phone wont switch on. |
The Following User Says Thank You to boystone2 For This Useful Post: |
10-27-2016, 08:29 | #8 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Make Flash IC test. If Flash IC test pass, make full erase with Keep preloader unchecked and flash again with the same version which was initially in phone. Br. Infinity Box Support Team. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
