Old 01-24-2021, 10:01   #1 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 18,880
[Q|A] : Why HWreport matter first on newer devices?
HWreport feature allow you NOT care about correct selection for/per device settings.
Preloader , DA in case of brom ( for default , and secboot configuration )
It allow rid off from most common issues :
DA : BOOT 2ND DA FAILED!
ERR : 0xC0070004
ERR : DA_HASH MISMATCH
DA : EXT_RAM NOT initialized!
     EMI : DEV : INFINITY
     EMI : SRC : PRELOADER_INFINITY_0
     EMI : CNT : 0002
     EMI : Init EMI from INTERNAL DB
     DA : SETUP EMI PARAMS FAILED!
  ERROR : ABORT
And sucessfully boot most of devices.
After once HW report done, check it result.
In some cases may be need UP EMI number in platfrom tab to sucess boot uncommon device configurations.
The Following 17 Users Say Thank You to JayDi For This Useful Post:
Old 01-24-2021, 14:20   #2 (permalink)
malka4u's Avatar
Member: 1626780
Thanks Meter: 1,068
2021 Is the year of hope. Thank you so much for this out of the box update.
The Following User Says Thank You to malka4u For This Useful Post:
Old 01-24-2021, 14:36   #3 (permalink)
Member: 1815000
Thanks Meter: 48
Xiaomi Mi Play MT6765 Failed
Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.17
Load IDBase v729152 Ok!
Preloader [HW DEV] Info :
EMI : DEV : MT6765
EMI : SRC : preloader_lotus.bin
EMI : CNT : 000A
EMI : [00] : eMMC : DDR3 : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 3.00 GB ]
EMI : [01] : eMMC : DDR3 : ID : 90014A484147346132 : VEN : HYNIX | DEV : HAG4a2 : RAM : [ 2.00 GB ]
EMI : [02] : eMMC : DDR3 : ID : 13014E53304A394237 : VEN : MICRON | DEV : S0J9B7 : RAM : [ 3.00 GB ]
EMI : [03] : eMMC : DDR3 : ID : 150100514536334D42 : VEN : SAMSUNG | DEV : QE63MB : RAM : [ 2.00 GB ]
EMI : [04] : eMMC : LP_DDR4X : ID : 90014A484347386134 : VEN : HYNIX | DEV : HCG8a4 : RAM : [ 4.00 GB ]
EMI : [05] : eMMC : LP_DDR4X : ID : 90014A68433861503E : VEN : HYNIX | DEV : hC8aP> : RAM : [ 4.00 GB ]
EMI : [06] : eMMC : LP_DDR4X : ID : 150100334836434142 : VEN : SAMSUNG | DEV : 3H6CAB : RAM : [ 6.00 GB ]
EMI : [07] : eMMC : LP_DDR4X : ID : 150100335636434D42 : VEN : SAMSUNG | DEV : 3V6CMB : RAM : [ 6.00 GB ]
EMI : [08] : eMMC : LP_DDR4X : ID : 90014A68433861503E : VEN : HYNIX | DEV : hC8aP> : RAM : [ 6.00 GB ]
EMI : [09] : eMMC : LP_DDR4X : ID : 450100444134303634 : VEN : SANDISK | DEV : DA4064 : RAM : [ 4.00 GB ]
Operation : HW Report [ v2.17 ]
HWreport : Mode : eMMC
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MTK USB Port (COM42)
MODE : BOOTROM
PORT : 42
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
CODE : Cervino
TYPE : MODERN RAPHAEL
BROM : MEID : E0BB0DA640A25719AB6BB65A4185BA9E
BROM : SecLevel : 0x000000E7
BROM : SecMode : SBC+SLA+SDA+EXT
BROM : BROM|BL : 0x05|0xFE
BROM : BOOTROM
MODE : 0_base : BASE_v2028 | Manual : Disabled
BROM : SOCID : 84C036F8DF1DBBD2F59B868B57AA166E0FBD9DCB1A0BBFBBBC EB73C722E6CC37
BROM : SLA : Local Auth
BROM : SLA : Auth Passed!
BROM : SLA : 0x0000001F
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6765
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SETUP HW PARAMS FAILED! PROTO_VER is OLD?
Error : Fail to init protocol!
>>> Check and select CORRECT SETTINGS for your device!
Reconnect Power/Cable!
Done!
Elapsed: 00:00:26
Old 01-24-2021, 14:39   #4 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 1,931
You have old DB version
Add your user+password to cm2mt2 setting to last DB update and retry
Old 01-24-2021, 14:46   #5 (permalink)
Member: 1815000
Thanks Meter: 48
SAME ISSUE !!! i Updated DB
Update configuration ...
Update Ok!
Load IDBase v1118158 Ok!
Operation : Identify [ v2.17 ]
Mode : FLASH
Device not found!
>>> Check cable, battery, connection and drivers!
MODE : BOOTROM
PORT : 42
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
Done!
Elapsed: 00:00:15
Old 01-24-2021, 14:52   #6 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 1,931
I THINK you use old proto in cm2mt2 setting
Change it to newest version [2]
Old 01-24-2021, 14:57   #7 (permalink)
Member: 1815000
Thanks Meter: 48
Tried 1 and 2 both failed
Old 01-24-2021, 14:59   #8 (permalink)
JayDi's Avatar
Member: 462970
How you connect device? Is it can power ON?
Old 01-24-2021, 15:02   #9 (permalink)
Member: 1815000
Thanks Meter: 48
Yes device hang on first logo ..
i connect with VOL DOWN
Old 01-24-2021, 15:05   #10 (permalink)
JayDi's Avatar
Member: 462970
Try with different BASE version 1944/192x.
If result same - seems as HW issue. Agent not starting at all.
The Following User Says Thank You to JayDi For This Useful Post:
Old 01-25-2021, 05:35   #11 (permalink)
Member: 1280685
Thanks Meter: 58
Question Oppo A12 CPH2083
Oppo A12 CPH2083
Identify / Connect
Mode : FLASH
PTFN : MediaTek USB Port_V1632 (COM24)
MODE : BOOTROM
PORT : 24
BROM : Init BROM
BROM init passed!
     CODE : Cervino
BROM : MEID : 0658268D83AB299D622C3ED872676B9B
BROM : SecLevel : 0x000000E5
BROM : SecMode  : SBC+SDA+EXT
BROM : BOOTROM
BROM : SOCID : 5BB9EDCCB63F1171BA4B39970E8CCBF495568A8E7BF6BC4BD2F7E41547BCAAE0
BROM : DA sent
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
     EMI : CNT : 0008
  ERROR : ABORT
>>> Internal EMI : Select other EMI number! External Preloader - make sure it correct for connected device!
Old 01-25-2021, 05:44   #12 (permalink)
gayansuranga's Avatar
Member: 230004
Thanks Meter: 158
Originally Posted by @ndoy View Post
Oppo A12 CPH2083
Identify / Connect
Mode : FLASH
MODE : BOOTROM
PORT : 24
BROM : Init BROM
BROM init passed!
     CODE : Cervino
BROM : BOOTROM
BROM : DA sent
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
     EMI : CNT : 0008
  ERROR : ABORT
problem is here
Old 01-25-2021, 06:58   #13 (permalink)
JayDi's Avatar
Member: 462970
Oppo A12 CPH2083
Identify / Connect
Mode : FLASH
MODE : BOOTROM
PORT : 24
BROM : Init BROM
BROM init passed!
     CODE : Cervino
BROM : BOOTROM
BROM : DA sent
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
     EMI : CNT : 0008
  ERROR : ABORT
So, in thread about need use HWReport first, you posting log, which you can avoid, by pressing that button...
Old 01-26-2021, 14:50   #14 (permalink)
Member: 1366785
oppo f11
Load IDBase v125162 Ok!
Operation : HW Report [ v2.18 ]
PTFN : MediaTek USB Port (COM73)
MODE : BOOTROM
PORT : 73
BROM : Init BROM
BROM init passed!
CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
CODE : Sylvia
BROM : MEID : AE99CB37D0C1D4893A76F9371B9FA99F
BROM : BOOTROM
MODE : 0_base : BASE_v2044 | Manual : Disabled
BROM : SOCID : E04FE63DFAB1C78005E24535A2A94C315DE1E99A3CB1753F0B C487BAEA1C9882
BROM : LOG : F0: 102B 0000 F3: 0000 0000 [0200] V0: 0000 0000 [0001]
AGENT : Found MT6771
BROM : 0x00007017 : DA SEND ERROR!
ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE!
INFO : BROM Level : CERT/AUTH required! Try boot device in PRELOADER mode with select PL/PL_CRYPTO/SWSEC type!
Info : LEGACY : HW reporting feature unavailable for current device!
>>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation!
Done!
Elapsed: 00:00:13
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.31292 seconds with 7 queries
