Old 11-04-2015, 20:36   #1 (permalink)
Member: 1228709
Thanks Meter: 268
Huawei MediaPad T1 ?
Hello dear supporter, i have in hands an MediaPad T1 with SC7731G inside.
I want to repair IMEI, but, im stuck here because i cant find drivers:
USB\VID_12D1&PID_4D01&MI_00
Operation : Check/Read Info [ v1.05 ]
1. Remove battery. Insert battery back
2. Insert cable
3. In case of SVC init problems - connect with hold "VolDown" button!
 ====  Wait for phone...
Phone found! [ 176 ]
Port Opened
Sync...
InitSvc Done
Wait for phone...
Device init not done
Check Drivers
Try again
Any help will be appreciated.
Old 11-05-2015, 07:53   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Hello. Normally it should be secured device and SVC mode will not work as expected.
Will check about it more today.
Old 11-05-2015, 11:20   #3 (permalink)
JayDi's Avatar
Member: 462970
Got device. Played with it. As expected it secured. In near few days make something for them.
The Following User Says Thank You to JayDi For This Useful Post:
Old 12-29-2015, 18:42   #4 (permalink)
Member: 1228709
Thanks Meter: 268
Hey, Jaydi, im working again with this tablet but i cant find the driver for that PID/VID
Im trying to repair imei.
Phone found! [ 59 ]
Port Opened
Sync...
InitSvc Done
Wait for phone...
Check Drivers
Try again
And, if i check write in flash mode, i get this:
Phone found! [ 59 ]
Port Opened
Sync...
Initial Boot Failed!
Elapsed: 00:00:26
Old 12-29-2015, 19:38   #5 (permalink)
Member: 1228709
Thanks Meter: 268
Update, now im stuck at this stage:
I had check all sldr but none is working, also, i dont found PAC for this tablet.
Phone found! [ 60 ]
Port Opened
Sync...
Normal Mode init
Sync...
Phone Initial Info :
Compile : œ
Phone Security Info :
IMEI [1] : 000005100C900E6
IMEI [2] : 602075627D69637
BT_ADDR : 007E6E6F6973
Done
Write new security data :
IMEI1 : 111111111111119
Write Error , 0x007E7E00
Elapsed: 00:00:23
Old 12-30-2015, 05:37   #6 (permalink)
JayDi's Avatar
Member: 462970
@JorgeVla, it have blocked SVC sub. Device on every command answer " not permitted " , also it not enter in FlashMode. That is reason why it not present in UpdateLog.
So, there is one way - SD upgrade. I have few ideas about how to work with it, but make something for only one device - strange idea. Will try anyway.
The Following 2 Users Say Thank You to JayDi For This Useful Post:
Old 08-17-2020, 18:34   #7 (permalink)
DjamelGsm's Avatar
Member: 1612184
Thanks Meter: 103
I need Driver this tab (Manufacture maintenance Mode)
USB\VID_12D1&PID_4D01&REV_2427&MI_00
Page generated in 0.17089 seconds with 9 queries
