Old 03-29-2019, 01:18   #1 (permalink)
Registered User
Member: 484250
Thanks Meter: 21
QLM doesn't detect devices in DIAG
Hello,
unfortunately the QLM module doesn't detect devices in DIAG mode. Drivers are installed correctly because the device is working fine in QxDM (QPST) and other tools detect it without any problems.
EDL detection is working fine but DIAG not.
Do you know what should be wrong please?
Why there is no manual COM port selection?
Old 03-29-2019, 01:36   #2 (permalink)
kundicom's Avatar
Member: 2650777
Sonork: 100.650600
Thanks Meter: 161
Originally Posted by MaClaud1 View Post
Hello,
right click on 9008 port driver now uninstall and restart pc and try again
Old 03-29-2019, 01:38   #3 (permalink)
kundicom's Avatar
Member: 2650777
Sonork: 100.650600
Thanks Meter: 161
Infinity box,dongle . support only emergency port on Qualcomm
Old 03-29-2019, 04:55   #4 (permalink)
malka4u's Avatar
Member: 1626780
Thanks Meter: 1,275
read qcn function only work in diag mode.. read carefully
Old 03-29-2019, 06:25   #5 (permalink)
maremestera's Avatar
Member: 691388
Thanks Meter: 371
As it was stated in a post before, to use qcom in hsusb9008 port, you need to install Emergencydrivers and it will be like Care emergency drivers in device manager, not com port
Old 03-29-2019, 07:36   #6 (permalink)
Registered User
Member: 484250
Thanks Meter: 21
9008 is port for edl operations but I need do operations in Diag mode which is different then edl (9008)
Sent from my Pixel 3 using Tapatalk
Old 03-29-2019, 07:45   #7 (permalink)
Registered User
Member: 2382850
Thanks Meter: 111
tick delete all driver qualcomm PC
Restar PC
install all driver qualcomm
C:\InfinityBox\CM2QLM\Drivers
done
Old 03-29-2019, 07:49   #8 (permalink)
Registered User
Member: 484250
Thanks Meter: 21
Do you zhink that thia is a driver issue? Tue device is detected by other apps with this driver without problems so why not by cm2?
Restar PC
done
Old 03-29-2019, 08:01   #9 (permalink)
Registered User
Member: 2382850
Thanks Meter: 111
https://www.youtube.com/watch?v=jzYb...ture=*********
test
Old 03-29-2019, 08:10   #10 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,420
Hello,
Hello,
Download this http://dl1.infinity-box.com/00/pub.p...ivers_v1.01.7z
Read carefully"Release txt" for instructions.
The Following User Says Thank You to Kirumira For This Useful Post:
Old 03-29-2019, 08:15   #11 (permalink)
Registered User
Member: 484250
Thanks Meter: 21
I understand but it is for edl = 9008 qualcomm driver. My troubles are with diag mode. It is totally different mode.
Edl - device turned off, used for frp, memory dump, flashing etc
Diag mode - device ON, used for qcn backup, imei repair etc.
The Following User Says Thank You to MaClaud1 For This Useful Post:
Old 03-29-2019, 08:26   #12 (permalink)
Registered User
Member: 2382850
Thanks Meter: 111
model you???????????
Diag oppo enable usb QPST boot ok*#800# or *#801#
ps Other model??????
Old 03-29-2019, 08:32   #13 (permalink)
Registered User
Member: 484250
Thanks Meter: 21
Alcatel 9007x but I enabled the diag port. Qpst communicates with it without problems but cm2 doesn't. Please chcek the picture in my first post - you can see that diag port is present but cm2 doesnt detect it.
Old 03-29-2019, 08:44   #14 (permalink)
Registered User
Member: 2382850
Thanks Meter: 111
INSTALL DRIVERS
Qualcomm HS-USB Android 9018
share gg
Old 04-01-2019, 23:49   #15 (permalink)
Registered User
Member: 484250
Thanks Meter: 21
Hi guys,
still no success. My driver is installed correctly but CM2 doesn't detect the device. I tested it with several computers, several devices and the result is still same - I cannot backup QCN and repair IMEI.
Can you explain me how to do that please? How CM2 does detect device in DIAG mode? please chek my situation:
Page generated in 0.20448 seconds with 8 queries
