05-13-2018, 16:14 | #1 (permalink) |
Freak Poster Join Date: Jul 2007 Location: Rawalpindi Pakistan Age: 37
Member: 541180 Status: Offline Sonork: 100.1626680 Thanks Meter: 147 | Qmobile A1 MT6755 After Flash wih Cm2 Dead. Phone Problem non. just wanna reset. 1-i have create Backup with cm2MTK 1.58. backup logo Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 20 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0002 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM46H [eMMC] : FLASH_CID : 150100524836344D42020B7CC21A24F9 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000E8F800000 [eMMC] : FLASH_UCP : 59640 MiB [eMMC 128 GiB] DEV RID : 0x0A20E4614308C35F54A55B6B779992E0 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : QMobile ProdName : Noir_A1 ProdModel : Noir A1 Device : QMobile_Noir_A1 AndroidVer: 7.0 MTKxCPU : MT6755 MTKxPRJ : SWW1609QM_0301_T6693 [Read Ok] : preloader_gnsz6755_66_n.bin [Read Ok] : recovery.img [Read Ok] : md1img.img [Read Ok] : md1dsp.img [Read Ok] : md1arm7.img [Read Ok] : lk.bin [Read Ok] : lk2.bin [Read Ok] : boot.img [Read Ok] : logo.bin [Read Ok] : tz1.img [Read Ok] : tz2.img [Read Ok] : secro.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6755 / V1.1.2 / gnsz6755_66_n / EMMC Android Info saved HWConfig Info saved FW Size : 4290 MiB Scatter saved to : C:\Users\QaiserSoftware\Desktop\MT6755__QMobile__Noir_A1__QMobile_Noir_A1__7.0__SWW1609QM_0301_T6693\ All done! 2-after Backup i have Format Reset setting with cm2MTK 1.58 3-Phone Stuck on logo i have wait more the 1 hour but same potion. 4-i have Restart phone by press all keys. but phone still stuck on logo i have wait 1 hour .but same stuck on logo. 5-then i Flash phone with my backup file which i have mad with cm2MTK 1.58. 6-Phone Flash successfully. but after flash phone not powering on phone Dead. i have also download Firmware From needroom.com and combinefile.com but after flash phone still dead. any budy have good idea how can fix. |
05-13-2018, 16:52 | #3 (permalink) | |
No Life Poster Join Date: Jul 2016 Location: Africa
Member: 2601900 Status: Offline Thanks Meter: 519 | Quote:
3-Phone Stuck on logo i have wait more the 1 hour but same potion. 4-i have Restart phone by press all keys. but phone still stuck on logo i have wait 1 hour .but same stuck on logo. 5-then i Flash phone with my backup file which i have mad with cm2MTK 1.58. 6-Phone Flash successfully. but after flash phone not powering on phone Dead. i have also download Firmware From needroom.com and combinefile.com but after flash phone still dead. any budy have good idea how can fix.[/QUOTE]if it was a secure boot phone, you made a mistake by flashing it with a backup file, it kills the phone because each firmware need to be signed | |
05-14-2018, 07:59 | #8 (permalink) | |
Member: 541180 Status: Offline Sonork: 100.1626680 Thanks Meter: 147 | Quote:
i have flash with cm2 mtk v2 here is logo Code: Operation : Write Flash [ v2.00 r2 ] Repartition : Enabled Flash Verify : Disabled Pre-Erase : Enabled Verify HW/SW : Enabled XData Backup : Disabled Files :16 [FL] : Set : preloader_gnsz6755_66_n.bin [FL] : Set : preloader_gnsz6755_66_n.bin [FL] : Set : recovery.img [FL] : Set : md1img.img [FL] : Set : md1dsp.img [FL] : Set : md1arm7.img [FL] : Set : lk.bin [FL] : Set : lk2.bin [FL] : Set : boot.img [FL] : Set : logo.bin [FL] : Set : tz1.img [FL] : Set : tz2.img [FL] : Set : secro.img [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0x10C2A0F95 [ 4.19 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM62) MODE : BOOTROM PORT : 62 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6755 EMI : SRC : preloader_gnsz6755_66_n.bin EMI : CNT : 0005 EMI : [00] : eMCP : eMMC+LP/DDR3 , ID : 150100523331424142 : VEN : SAMSUNG | DEV : R31BAB : RAM : [ 3.00 GB ] EMI : [01] : eMCP : eMMC+LP/DDR3 , ID : 150100525831344D42 : VEN : SAMSUNG | DEV : RX14MB : RAM : [ 4.00 GB ] EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 150100524331344D42 : VEN : SAMSUNG | DEV : RC14MB : RAM : [ 4.00 GB ] EMI : [03] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344D42 : VEN : SAMSUNG | DEV : RH64MB : RAM : [ 4.00 GB ] EMI : [04] : eMCP : eMMC+LP/DDR3 , ID : 150100475836424D42 : VEN : SAMSUNG | DEV : GX6BMB : RAM : [ 3.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 150100524836344D42020B7CC21A24F9 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : RH64MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 4308C35F54A55B6B779992E0844C845E DA : USB : FULL-SPEED Boot done! [FL] : HW verification passed! [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Write : PRELOADER_BACKUP Write : RECOVERY Write : MD1IMG Write : MD1DSP Write : MD1ARM7 Write : LK Write : LK2 Write : BOOT Write : LOGO Write : TEE1 Write : TEE2 Write : SECRO Write : SYSTEM Write : CACHE Write : USERDATA [FL] : Flashing finished! Done! Elapsed: 00:02:56 Reconnect Power/Cable! but phone still not powering on if you have Factory Signed Firmware for this kindly share with me. | |
05-14-2018, 11:36 | #9 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | You should use MT2 module for FW Read/Flash. Since FW read with old module version - can't say anything useful, except read from another alive device or get factory/good read with 2.x line. |
05-15-2018, 16:12 | #10 (permalink) |
No Life Poster Join Date: Oct 2015 Location: Unknown
Member: 2469611 Status: Offline Thanks Meter: 389 | Code: but phone still not powering on if you have Factory Signed Firmware for this kindly share with me Code: Board Platform : mt6755 Build Time : 1496897537 Display ID : Noir_A1 Patch Level : NRD90M Product Info : gnsz6755_66_n Ver. CodeName : REL Ver. Release : 7.0 Sec. Patch : 2017-05-05 Product Board : Noir_A1 Product Brand : QMobile Product Device : QMobile_Noir_A1 Product Manfct : QMobile Product Model : Noir A1 Product Name : Noir_A1 MT6755__QMobile__Noir_A1__7.0__Noir_A1__NRD90M__gnsz6755_66_n Read : preloader.bin Read : recovery.img Read : proinfo.img Read : md1rom.img Read : md1dsp.img Read : md1arm7.img Read : nvram.bin Read : lk.bin Read : boot.img Read : logo.bin Read : tz.img Read : secro.img Read : system.img ExtSparse : Compression ratio : 13% Read : cache.img Read : userdata.img FW Size : 3.69 GB Android Info saved : _Android_info.txt Scatter : MT6755_Android_scatter.txt Saved to : C:\InfinityBox\CM2MT2\Flash\New folder\MT6755__QMobile__Noir_A1__7.0__Noir_A1__NRD90M__gnsz6755_66_n\ Done! Elapsed: 00:05:55 BR |
The Following User Says Thank You to CYB3R GSM For This Useful Post: |
05-16-2018, 07:44 | #11 (permalink) | |
i need firmware kindly give me link | |
05-16-2018, 07:59 | #12 (permalink) |
No Life Poster Join Date: Aug 2011
Member: 1630066 Status: Offline Sonork: 520074 Thanks Meter: 215 | arrange same model alive condition dump firmware by eft dongle and write dumped file on dead mobile or second solution is that read full firmware as bin file using any dongle or box and write bin file on dead mobile |
The Following User Says Thank You to ilyasrao For This Useful Post: |
05-18-2018, 08:55 | #14 (permalink) |
Member: 541180 Status: Offline Sonork: 100.1626680 Thanks Meter: 147 | My Qmobile A1 MT6755 Problem is Done By Factory Signed Firmware Via CM2MTK V2[BCode: Operation : Write Flash [ v2.00 r2 ] Repartition : Enabled Flash Verify : Disabled Pre-Erase : Enabled Verify HW/SW : Enabled XData Backup : Disabled Files :16 [FL] : Set : preloader_gnsz6755_66_n.bin [FL] : Set : preloader_gnsz6755_66_n.bin [FL] : Set : recovery.img [FL] : Set : md1rom.img [FL] : Set : md1dsp.img [FL] : Set : md1arm7.img [FL] : Set : lk.bin [FL] : Set : lk.bin [FL] : Set : boot.img [FL] : Set : logo.bin [FL] : Set : trustzone.bin [FL] : Set : trustzone.bin [FL] : Set : secro.img [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0xEB3B1B6C [ 3.68 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM10) MODE : PRELOADER PORT PORT : 10 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 150100524836344D42020B7CC21A24F9 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : RH64MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 4308C35F54A55B6B779992E0844C845E DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Write : PRELOADER_BACKUP Write : RECOVERY Write : MD1IMG Write : MD1DSP Write : MD1ARM7 Write : LK Write : LK2 Write : BOOT Write : LOGO Write : TEE1 Write : TEE2 Write : SECRO Write : SYSTEM Write : CACHE Write : USERDATA [FL] : Flashing finished! Done! Elapsed: 00:02:38 Reconnect Power/Cable! Thanks My All Friends Who Give Me Suggest BR Qaiser Jameel |
