10-23-2015, 09:24 | #1 (permalink) |
No Life Poster Join Date: Dec 2010 Location: pakistan
Member: 1466124 Status: Offline Thanks Meter: 116 | qmobile A10 mt 6577 supported ? other tool all ok but cm2 Operation : Check / Read Info [ v1.34 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Brom Init not done Boot Error! Operation Failed Elapsed: 00:00:02 Reconnect Power/Cable! |
10-23-2015, 11:05 | #4 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: Pakistan
Member: 192810 Status: Offline Sonork: Some people NEED change Thanks Meter: 860 | Quote:
Change the USB Port. I've done very long ago no Problem at all. Code: Operation : Check / Read Info [ v1.18 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 92 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8B00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 0300771F SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : HYNIX [eMMC] : FLASH_CID : 90014A2058494E594812A16426D79FF5 [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : A10 ProdName : A10 ProdModel : A10 Device : A10 AndroidVer: 4.1.1 MTKxCPU : MT6577 MTKxPRJ : ALPS.JB.MP.V1 Done! Elapsed: 00:00:10 Reconnect Power/Cable! | |
10-23-2015, 11:16 | #5 (permalink) | |
Member: 1466124 Status: Offline Thanks Meter: 116 | Quote:
10-23-2015, 11:34 | #7 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | I have no idea. Some guys told it work well with bootcable or pressed side keys. I will not change anything due one phone problem. |
10-23-2015, 12:40 | #9 (permalink) | |
this mean no suppot for my 1 phone ? phone ok and on position. only signal problem with damage baseband connect other devices just insert cable ....... any suggestion ? | |
10-23-2015, 14:37 | #11 (permalink) |
Member: 1466124 Status: Offline Thanks Meter: 116 | sir don't mind, using other tool mobile okkkkk i completly understand your post but my quistion is, why phone not conneting the cm2 other tool connecting very well, phone completly on position and work well this time, need to read factory flash this time but not able to read if you need to test i send you team viewer |
10-23-2015, 15:00 | #12 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | I need it on hands to check. Because there at now just this one not connect. But modify something without mobile - can bring just new problems. |
10-23-2015, 15:37 | #14 (permalink) |
No Life Poster Join Date: Sep 2006 Location: ---> Hope
Member: 355782 Status: Offline Thanks Meter: 1,265 | I often face same problem phone detect with other tools but unable to CM2 exactly same error above and pc restart always solve the problem. I also face sometimes others unable to detect phone but CM2 can. This is because sometimes tool remember ports last status and not refresh that status and think port is busy or maybe voltage issue I m using laptop. |
10-23-2015, 21:01 | #15 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Just use pinouts frm other box and try sometimes this cpu prblm with USB so detect pinouts frm another box tryed with micromax a110 Sent from my GiONEE S7 using Tapatalk |
