08-03-2018, 14:18 | #1 (permalink) |
No Life Poster Join Date: Mar 2014 Location: Romania
Member: 2157664 Status: Offline Thanks Meter: 43 | ZTE Blade V7 Lite dead I have a dead ZTE Blade V7 Lite and when I try to flash I get this. Chinese Miracle II [MTK module] v 1.58 Scatter Load Ok , BaseBand : MT6737 , Project : ztexa6735m_35u_m , Storage : EMMC Files found : 11 , Set to Flash : 10 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : ZTE Device Model : ZTE_BLADE_V0720 Device CPU : MT6735 Device IntName : P635A32_EU Device Version : 6.0 Device Compile : 8/25/2016 1:03:05 PM Device Project : ZTE_BLADE_V7_LITE_B13 Device ExtInfo : ZTE BLADE V7 LITE Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 42 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 460001154D32314EC7930642ADA8A2F2 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM21N [eMMC] : FLASH_CID : 150100464E31324D420693C7F2A263AD [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xCA6E4BB7A2027F335D05667019D16F90 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6737 , Project : ztexa6735m_35u_m , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled Switching to HSUSB HSUSB Init Ok BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3942 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000001C80000-0x0000000004E00000 Erase : 0x0000000006B80000-0x00000001C9480000 Flash Pre-Erase Done, time used : 00:00:00 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_ztexa6735m_35u_m.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : FFFFFFFF PartErr : Not initialized , will update PMT now ... Repartition Failed! Something wrong with HW or BL? Try make "Flash Erase" first! Operation Failed Elapsed: 00:00:41 Reconnect Power/Cable! What can I do pls? |
