05-01-2019, 10:09 | #1 (permalink) |
No Life Poster Join Date: Nov 2014
Member: 2289628 Status: Offline Thanks Meter: 226 | Qmobile B60 can`t do "Format FS" It can read "Check/Info" but can`t do "Format FS" and write there to contact support team. Code: Operation : Check Device / Info ======= Settings Settings : Read AllInfo is Off Settings : Full Boot disabled by default Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Init : 01C701C6 Settings registers ... 1st boot Ok ==== CPU CPU_ID : 0809 , rev : 0007 CPU_CN : ==== FLASH FL_VEN : 0000 , rev : 0000 FL_CNM : FL_CAP : 00000000 Initial : 81C0024C Boot Done! Elapsed: 00:00:25 Done Reconnect Power/Cable! Operation : Format File System Settings : SmartFormat is On Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Init : 01C701C6 Settings registers ... 1st boot Ok ==== CPU CPU_ID : 0809 , rev : 0007 CPU_CN : ==== FLASH FL_VEN : 0000 , rev : 0000 FL_CNM : FL_CAP : 00000000 Initial : 81C0024C ==== Booting Sending RamRun Loader ... Set : 0809 , 00000000 Boot File Not Found! CPU not Supported , or BootFiles are missng. Contact to Support! Reconnect Power/Cable! |
05-01-2019, 16:16 | #2 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Hello, Use SCR module for 6533G http://forum.gsmhosting.com/vbb/f296...tures-2565793/ |
