04-27-2016, 14:35 | #1 (permalink) |
No Life Poster Join Date: Nov 2007 Location: In Apple Device
Member: 638481 Status: Offline Sonork: 100.1601053 Thanks Meter: 749 | QMobile E9 White Display After Flashing !!! i have Qmobile e9 (cpu 6250 ) befor flashing it have just prob whan i add new contect its gone in whote lcd now i flash many many file which is uploaded in this forum but Now just Show Qmobile & white Display Any solution pls Guide if Can Thanks hare is Flashing Logs Wait for phone... Phone found! [ 28 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : E2195CBAE0E02EEF52F780491E72D1FE BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : 2C00 CB00 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EE , [Numonyx] N25W128 [0] : FLASH_DIE : 002C 00CB 0018 0000 [0] : FLASH_LEN : 0x01000000 INT_RAM : 0x0000D400 EXT_RAM : 0x00800000 SDS_INFO : Not exists File_Info : WBG1300QM_0201_PCB01_gprs_MT6250_S00.1300QM_0201_V 0529.bin FileVersion : 1300QM_0201_V0529 Flash now Erase region , wait ... Write data , wait ... Write : E9 Q mobile WBG1300QM_0201_PCB01_gprs_MT6250_S00.1300QM_0201_V 0529.bin Done! Elapsed: 00:04:27 Reconnect Power/Cable! |
04-27-2016, 14:40 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Do you not think about it is HW? Did you make it original backup before? Does format not help, before you start flashing inside it different dumps? |
04-28-2016, 13:10 | #6 (permalink) |
No Life Poster Join Date: Apr 2009
Member: 1015645 Status: Offline Thanks Meter: 114 | sir any set you receiecd from cutomer first of all make a bakup then will try any procedure here is flash file qmobile e9 mt6250 s00.1300qm v0529 - Download - 4shared - GSMFLASHING GSMFLASHING |
